| ------------------------------------------------------------------------------------------ For fear that a medium preload was too I have already orderd carriage with light preload but I picked up the ball cage model. I will not use cutters more than 10 mm in diameter. The model carriage is: QHW20CCZ0H static load 25630N = 2615 Kgf dynamic loading 23080 N = 2355 Kgf Preload (0 to 0.02)>> 23080x0.02 = 461.6 N = 47.10 Kgf I will use 4 for each plane, therefore Total Preload 47.10 Kgf* 4 carriage = 188 kgf for plane Do not know if this will be good or bad. What do you think? thanks a lot Last edited by luis81; 12-24-2010 at 10:04 AM. |
| Hello mactec54, I can change the order but I have doubts, so I will provide more data on my cnc project. The configuration I want to do is like the machine you see in the picture below. ![]() My gantry weighs approximately 32 kg For ballscrew I'll buy it on ebay, chinese ballscrew diameter 20 mm and 5 mm pitch. If I choose a large preload the ZA then the total preload would be approximately 471 and 659 Kgf but I think it can be much. In this case how much force should have a minimum motor for normal operation? Don't need high cutting speeds. Thanks a lot Last edited by luis81; 12-26-2010 at 04:35 AM. |
#11
| My gantry Weighs Approximately 32 kg. For ballscrew I'll buy it on ebay, chinese ballscrew diameter 20 mm and 5 mm pitch. If you choose half guides preloaded total theoretical preload would be between 471 and 659 Kgf. With AC servos from DMM Technology : High Torque Brushless AC servo motor Rated torque: 2.9 Nm(409 oz-in), peak torque: 7.2 Nm(1015 oz-in), Max Speed >1000rpm, Peak power 900W. Would be sufficient to obtain optimum speed connecting them directly to the shaft ??. I do not intend to obtain large cutting speeds. Thanks a lot Last edited by luis81; 12-30-2010 at 04:06 AM. |
| Selection of guideways in Waterjet CNC | davin | Linear and Rotary Motion | 1 | 07-30-2010 07:26 PM |
| Did my best to preload ballnut, but no success. | alexccmeister | Linear and Rotary Motion | 12 | 09-07-2008 09:33 AM |
| Preload Nuts | pzzamakr1980 | Benchtop Machines | 12 | 03-13-2008 10:38 PM |
| preload ? | andy55 | Linear and Rotary Motion | 5 | 01-04-2006 06:28 PM |
| Adjustable preload- Will this work? | spoiledbrat | DIY-CNC Router Table Machines | 0 | 05-15-2005 12:12 AM |
