Old 12-15-2010, 05:41 AM
welshtom is on a distinguished road
MIC6 Aluminium thickness
Hi all
I have a small CNC machine which i use to cut mainly sheet alu.
Recently I've been dabbling with engraving with it and I am pleased with the results.
however unlike my normal cutting this requires a true flat surface, especially as I plan to engrave over a 500x500mm area.
I have been getting quotes for a 540x540mm piece of MIC6 Aluminium which I figured would be the best type to use.
My question is thickness, would 10mm suffice?
I have 3 support struts underneath this piece at equal spacing that would run the full length of the piece
Would 10mm keep its flatness across these gaps? Or would I be better with 15mm or 20mm?
Thanks for any help.
Tom
Old 12-15-2010, 09:33 AM
Perfect Circle's Avatar
Perfect Circle is on a distinguished road
The thicker the better, for staying rigid & flat.
"you can always have too much"
Old 12-15-2010, 11:01 AM
ger21's Avatar
Place a piece of MDF on the bed, and surface it flat with the machine.
Old 12-15-2010, 11:13 AM
We've been using MDF/Hardboard for our general work cutting patterns in aluminium mainly.
Thats fine but only for so long as we use a coolant which does get soaked up.
Within 1 or 2 engraving jobs the wood is unusable. It needs to maintain a high degree of flatness for large engraving jobs.
a 0.5mm rise or fall across a half a metre bed is disasterous
This is why we are changing to a metal solution just for engraving, with a view to be able to take this bed on and off as we need to
I think 10mm will suffice, its works out approx 50% extra for double thickness though so it its tempted to go 20mm and be "safe"
Old 12-15-2010, 09:28 PM
DSIF is on a distinguished road
Wink
MIC6 aluminum is cast and blanchard ground. Usually flat within .005". I would anchor it and machine it flat for use as a fixture.
Dan
Old 12-16-2010, 03:23 AM
Hi
This is why we picked it, for its cast nature and flatness.
Can anyone answer my question thought?
Would 10mm be sufficient
Tom
Old 12-18-2010, 06:25 PM
Wink
Tom-follow your instincts. 10mm is very thin for a fixture. The thicker fixture will provide better results. Plus,as it wears, you can resurface it. I would use 25.4mm(1.0").
Dan
Pines Numbers 3&4 Benders Frame Thickness and Nose Thickness morribi Bending, Forging,Extrusion... 6 02-03-2010 09:59 PM
MIC6 Aluminium wfung Australia, New Zealand Club house 0 04-30-2009 09:08 PM
Amperage vs. Thickness johntm CNC Plasma and Waterjet Machines 1 09-21-2008 11:32 AM
Need Help!- Zero thickness in cut loft Michael El Solidworks 9 06-18-2008 04:58 PM
