Old 12-09-2010, 09:46 PM
-Rich87T is on a distinguished road
How to machine a ball socket...
I want to make a replacement bushing for my car's shifter... I apologize for not having a drawing or diagram on hand.
The piece is a simple 1.5" cylinder of nylon/plastic about 1.0" tall.
The center is milled out to make it a 'tube' with an ID of 1.0" (.25" wall).
It has 8 slots cut through it, .75" deep and .50" wide.
That last step creates semi-flexible "fingers" that can expand around the metal ball (and post) that the shifter pivots on. The idea is that you 'snap' the bushing over/onto the metal ball, then insert that into the transmission housing.
The next step is where I'm hung up... I need to create a 1.3" diameter SOCKET inside the bushing. The socket needs to be centered. I have no idea how to make a socket for this ball to fit into? I thought about using a 1" ball mill but my initial searches say the cost is too high. I could make my own tool but if there's a more conventional way to do this I'm all ears.
I have a Shoptask CNC mill/lathe, TIG welding ability and a well equipped garage. Can someone point me in the right direction?
Old 12-10-2010, 12:14 PM
keebler303 is on a distinguished road
Use a boring bar and interpolate the round on the ID of the part in your CNC lathe.
Matt
Old 12-10-2010, 01:21 PM
I will laugh if it's that simple.
I didn't think I'd have enough clearance but it appears my 1/2" bore bar might be able to get deep enough to make the socket I need...
Thank you for replying and not bashing my simple oversight.
Old 12-10-2010, 02:31 PM
Its only a .15" undercut. If it doesn't clear, grind it until it does. You could also make a boring bar more fit for the purpose if necessary.
Matt
Need to machine threads on a socket extension wwendorf General Metalwork Discussion 3 06-01-2010 08:51 PM
Need Help!- V23 - Cant figure out how to machine a ball GITRDUN BobCad-Cam 6 02-11-2010 12:25 PM
Any source for pre-made ball/socket joints? SRT Mike General Metalwork Discussion 10 05-27-2007 05:53 PM
Machining an R8 Socket Woodie1 General Metalwork Discussion 2 05-26-2006 02:47 PM
Ball Screws for my machine CNC Brute DIY-CNC Router Table Machines 2 01-27-2004 03:11 PM
