| For my die sets I use either A-2 or O-2 tool steel. Machine, grind or EDM it to the shape that I need. Send it off to the heat treaters and have them heat treat it to 60 to 65Rc. When it returns grind an edge on it and... Wa-La Have cut/ punched steel up to 5/16" thick with no problems.
__________________ If it's not nailed down, it's mine. If I can pry it loose, it's not nailed down. |
| Most all shearblade I build, I use A2 tool steel, some S7 and some D2. I find when shearing is done under severe circumstances, like wrong clearance setting, lose knife, cut most sizes, cut when shear is dull, guys half asleep.....and so on, is best not to harden too hard!...usually 52 to 54 RC is best, otherwise it will chip at 60RC.most definitely. Konrad |
| Go with the A-2 - I agree. Good, tough stuff. If the blade is thin, then you may want to cool it between two heavy plates to minimize warping or twisting. Scott
__________________ Consistency is a good thing....unless you're consistently an idiot. |
| BT30 taper spindle to cut tool steel? | grantmi1 | General Metalwork Discussion | 0 | 05-31-2005 12:02 PM |
| CAM Software selection help; | fyffe555 | General CAM Discussion | 3 | 07-25-2004 10:13 PM |
| Motor selection | Konstantin | DIY-CNC Router Table Machines | 2 | 03-14-2004 01:08 AM |
| Tool selection help | Schulze | General Metal Working Machines | 2 | 12-30-2003 12:35 AM |
| 3/8 Ball Endmill in Tool Steel | Freddy | Hard and High Speed Machining | 2 | 09-08-2003 04:13 PM |
