Old 07-11-2005, 05:52 AM
rustyolddo is on a distinguished road
Question Help Centering a Conical part.
I have a funnel shaped part that I need to machine the edge or rim face if you will in the mill. The ID & OD are unfinished so using a standard DI center finder won't work well. I could simply use an edge finder but the precision might vary due to the unfinished OD. The part has a hole in the bottom so I can run a pin up thru the center. Looking for suggestions. Think about how you'd center up a funnel in the mill. Thanks.
Old 07-11-2005, 08:03 AM
DACMACHINE is on a distinguished road
How about mounting a dial indicator mounted in the spindle
as you rotate spindle you can see, how much to move table
to center it
Dan
Self centering fixture Hack Mechanical Calculations/Engineering Design 18 07-13-2005 12:09 AM
Cad Cam Go Part fragger6662000 General CAM Discussion 0 04-01-2005 12:07 PM
Centering a 4-Jaw chuck gdl357 Mini Lathe 10 09-20-2004 06:24 PM
Centering blocks Hobbiest DIY-CNC Router Table Machines 4 02-09-2004 11:57 PM
My first part JOE65 DIY-CNC Router Table Machines 21 06-01-2003 12:42 PM
