Hello, We were using a radius cutter to cut a radius on a small mold centralizer. The centralizer's diameter was 2.036", and the cutter radius is .5". I understand the I and J addresses. The X and Y coordinate words in the G41 block represent the arc starting point, right? The J value is the centralizer radius plus 1/2 the cutter diameter away from the center of the arc. The center of the arc is part zero in this case. What's up with line N99. G2 is still in effect 'cause its modal. So the X and Y coordinate words in line N99 represent end points of an arc starting at X.0005 Y1.268, right? That doesn't make any sense to me. Is this some of that "lead-out" arc style code? I'm in absolute mode, so those are absolute values, right? It doesn't seem like the cutter could move to that location without hitting the part. I didn't get to run the code, just trying to understand it. Any help greatly appreciated. (.500 Radius Cutter) S325 M3 G90 G0 X.0006 Y1.3 G43 Z1. H18 T5 Z.1 M8 G41 X.0005 Y1.268 D18 F4. G2 I-.0005 J-1.268 N99 X.8999 Y.8933 I-.0005 J-1.268 G40 G1 X.900 Y.900 G0 Z1. M101 G28 Y0 M30 |
| I installed NCPlot evaluation version from Peter Smid's book and was able to look at it. X.8999 Y.8933 I-.0005 J-1.268 continues a short "lead-out" arc at the same distance from arc center (part zero) as the initial G2 full circle. X.8999 Y.8933 looks like its at a dead 45 degree angle from part zero in Quadrant 1 of the circles circumference. |
| Need Help Mazak T32-3 Circular Interpolating | dcorrick | Mazak, Mitsubishi, Mazatrol | 0 | 07-20-2009 03:10 PM |
| Need Help!- Circular Cut | mikelohj | LinuxCNC (formerly EMC2) | 1 | 06-18-2009 12:19 PM |
| Newbie- Circular Interpolation | Deadwood | Mach Software (ArtSoft software) | 3 | 01-11-2009 02:35 PM |
| What do you know about this circular saw??? | mailloux | WoodWorking | 5 | 10-16-2007 10:34 PM |
| Circular Cut | Sanghera | GRZ Software- MeshCAM | 13 | 11-13-2006 10:26 AM |
