Old 12-02-2010, 08:41 AM
ngwanhoe is on a distinguished road
How to hold a large diameter rod to the spindle?
I am trying to hold a 32mm aluminium rod to the spindle of a mini vertical mill which has MT3 taper. Any idea?
If using jaw 3'' chuck jaw the clamping depth is not deep enough.
1) Any DIY tools idea?
2) Converter for longer chuck jaw?
Old 12-02-2010, 09:32 AM
Any MT3 Collet chuck that hold 32mm?
Old 12-02-2010, 06:41 PM
I think I will make a jaw clamp.
Using round tube with 4 bolts on the side.
large diameter workpieces on sl-30 pmurdock Haas Lathes 4 07-28-2009 12:15 AM
Drilling / Milling Stone - Large Diameter Ball End Mill oscarbam General Material Machining Solutions 5 08-27-2008 05:29 PM
large diameter end mills?? jlembas General Metalwork Discussion 8 06-07-2006 09:12 PM
Large Diameter Drilling PolyPill General Material Machining Solutions 14 02-01-2006 07:40 AM
Cutting Large Diameter Holes in Aluminum Plate barkster General Metal Working Machines 18 04-07-2004 05:44 AM
