| I need to go between 7.7 degree station using a 0.9 degrees stepper motor. This meens a 300:1 gearbox. Now i need to calculate this using small spur gears from 12-80 theeth. Is the a website that has a calculator online to calculate the correct gears to use or a simple calculater somewhere else? |
| After downloading the package i got a vires message from my scanner. But i found a better one here: But now i have a mental block. Using the above calculator i came up with a three stages gearbox. The first gearset being 32:80, the second 48:80 and the third and last 40:80. But now i need to know how many steps the stepper must make to turn the last gear once. Any input would be helpful ![]() p.s. the 7.7 in my first post should be 7.5 |
| calculating tooth thickness in spur gears | coykiesaol | Mechanical Calculations/Engineering Design | 2 | 11-02-2010 10:08 AM |
| Need A Quote- Spur gears in Delrin | scsi | Employment Opportunity | 2 | 09-21-2010 10:33 AM |
| Need Help!- Gorilla Spur Gears | Lightfoot | Gorilla CNC Machines | 1 | 08-10-2009 12:01 AM |
| Need Help!- Spur Gears | warossignol | Mini Lathe | 0 | 06-09-2009 10:30 AM |
| anyone using Rack and spur gears | kfranklin | Linear and Rotary Motion | 8 | 05-10-2007 08:43 AM |
