| I ve problems with 316L. We are working for defense industry and stainless steel milling is what we have to deal always. Milling is easy. We can fit almost all the toleranses. But after we take the peice out from the machine there is always a bending. Altough we face mill both parts when we put the peice on a plate there is always a "u" shape. What can I do to solve the problem. |
| If you are removing alot of material from the stock . You may want to roughout the part first, on all the milling operations. leaving enough for a finish pass on all the critical dimentions. After all the work pieces are roughed, then start with your finish passes. this has worked for me in the past. |
Do you know wheather there is a heat thretment, quenching for the stainless steels?. Lots of force going on under 316L' I suppose . And one last thing, Tapping. Why it is so hard for small threaths. M4 and M5 tapping kills me. Is there any advise you can give for tapping and any tool brand? |
| all stainless steel is tough to work with. usually more tough than hard. I don't know of any heat treatment that would make it any less of a pain to work with. as far as tapping it . see what the engineers require for % of thread. sometimes you can drill it a little oversize ( not much). to make it easier for the tap. You do need a good quality tap, there are several, OSG and Greenfield make a good tap, also a really good tapping fluid will help. I have had good luck with a product called (Molly Dee). good luck with all of your projects. |
Delw |
#10
| There is a paste for taping that I've always had good luck using on 316ss.Intercon Online - InterPurge, Baer Hardware, Jokisch Fluids, Tigrip, Hardy Non-Sparking Tools |
| Need help, milling 316 stainless steel, 1mm endmill. Keeps snapping. | GMitchell | General Material Machining Solutions | 4 | 10-16-2011 09:41 PM |
| milling stainless steel | peaceandcalm | General Material Machining Solutions | 9 | 09-06-2010 10:14 PM |
| Milling 420 Stainless Steel | Talisman | General Metalwork Discussion | 4 | 12-06-2008 12:57 PM |
| Milling 440c Stainless Steel | jafgreen | General Metalwork Discussion | 2 | 10-30-2007 08:12 PM |
| Drilling Stainless 316L | Stoneair666 | General Metalwork Discussion | 28 | 05-01-2007 07:51 AM |
