Old 07-04-2005, 12:01 PM
*Registered User*
ChrisJ is on a distinguished road
8" Rotary Table Disassembly
I purchased a Phase II 8" rotary table.
I disassembled everything I could and I am stuck on one area.
I can't seem to figure out how to remove what is holding the worm shaft in. The diagram indicates that there is a 5x6mm set screw and a threaded pin. When I look in the bored hole in the casting with a flashlight all I see is what appears to be a head of a screw or bolt with a round hole in the center. I have tried different size allen wrenches, but I get no bite.
Has anyone taken this table apart, that would know how to remove what they are saying is a set screw?
I left this question for the distributor but have not received a call or email back with the answer.
Chris
Old 01-25-2008, 02:08 AM
billfle is on a distinguished road
8" Rotary table
It may be a roll pin, not a screw?
regards
Bill
60$ rotary table? vacpress General Metal Working Machines 22 10-30-2007 08:12 AM
where to find a cnc 4th axis table "servo"?? mik32176 General Metal Working Machines 3 04-20-2005 08:47 AM
Wholesale Tools 6" rotary table CerveloRod Benchtop Machines 2 03-27-2005 11:11 AM
Rotary Table Req h_2_o General Metal Working Machines 9 02-08-2005 02:11 PM
Calculating "steps per unit" for rotary axis? Beezer Mach Software (ArtSoft software) 2 11-28-2004 04:31 PM
