Old 11-13-2010, 07:47 PM
capt jim is on a distinguished road
What are these lathe tool abbreviations?
Hi gang...I am obviously a newbee, and just bought a MicroLux 7 X 16 mini lathe. I want to buy some cutting tools, and I am unable to find any definition to these tool tip type designations. How about someone passing along the definitions for these abbreviations. The following is a copy of the ad selling a set of these cutting tools, and the abbreviations that are leaving me scratching my head!!!.
Thanks for the help.
Jim
C6 GRADE, 4 PCS BR4, 4 PCS BL4, 4 PCS C4, 4 PCS D4 8 PCS AL4, 8PCS AR4, 6 PCS E4, ALL NEW C6 GRADE FOR CUTTING STEEL.
Old 11-13-2010, 08:26 PM
Medm's Avatar
Medm is on a distinguished road
The C6 designation is for a style of brazed tungsten carbide.
Most are 1/2", the AR/AL/BR/BL refer to different shapes for various turning operations. The larger the number after the letter designation, the bigger the size of tool.
12 = 3/4" ; 10 = 5/8" ; 8 = 1/2" ; et cetera.
R = right hand ; L = left hand
A = OD/facing straight; B = OD/facing angled; C =
D & E = OD sharp/threading tools;
C6 is appropriate for most materials and a good choice for all around flexibility.
These are all old style tooling and appropriate for the lathe in question.
Old 11-14-2010, 06:41 PM
re lathe tool abbreviations
Thank you so much for taking the mystery out of that abbreviations issue.
I will go ahead and buy that tool set.
Bye for now.
Jim
Newbie- Anyone used FeatureCam with Omniturn Lathe / Gang Tool Lathe? dbensavage FeatureCAM CAD/CAM 5 02-22-2010 07:39 AM
Lathe - Which tool would you use? mrogowski General Metalwork Discussion 11 08-31-2009 09:21 AM
Lathe finishing tool? penjas14 General Metalwork Discussion 2 12-19-2008 11:18 AM
Need Help!- I need sugestions on what lathe tool to use ryansuperbee General Metal Working Machines 4 08-12-2008 06:36 AM
Lathe Tool Turret mikemill General Metal Working Machines 2 12-15-2007 09:57 AM
