11-13-2010, 12:46 PM
Well, I can tell you that you want to have parts with the tightest tolerance possible...
You should get nema-17 motors with high precision, 8-wire, bipolar, 0.9 deg, 400-step motors. Drive-screw should be greater than 20-turns per inch, which would be most 1/4 inch machine screws (1/4-20X6"). Drive-screw length should not be longer than 6", for both X and Y axis. Z axis can be the same, but for superior depth control, use a metric (8-32x6") machine screw.
Use a pencil air-drive, jewelers engraving tool and bits.
Keep your drive-screws as close to the working area as possible, with double-wide glides for the most accurate precision. Eg, that 6" thread should only give you a 3"x3" XYarea with no more than 3" of Z lift. 3" of that lead-screw should be used for the mounts...
Mount area in the center. [=]mount-plate[=]
Use super-small RC helicopter bearings, or printer-slides. You can get them by the hundreds, for about $20.00 USD.
Get a good set of digital calipers, and measure measure measure. Invest in a small metal lathe, you may need a lot of custom parts that can't be purchased for less than the cost of the lathe. (From wear and tear.)
Stainless-steel, all the way through... Polished, if possible, chromed if not possible to polish. (Chrome chips in time and can't be "fixed", polishing can be re-polished and re-ground if needed.) |
