Old 06-30-2005, 05:09 PM
ViperTX is on a distinguished road
Lovejoy Tooling
I have a 2inch Series 205 face mill, their catalog does not specifically say that you need to buy their arbor, but it seems that you do. I've checked all the 3/4 inch R8 arbors that I have and none will work with this facemill.
Anyone have a similar Lovejoy experience?
Thanks,
Paul
Old 06-30-2005, 06:51 PM
psychomill is on a distinguished road
What part of it doesn't work? It appears to be just a 3/4 hole, is it the keys not fitting? Haven't had any problems with other Lovejoy stuff.
Old 06-30-2005, 09:40 PM
I may have jumped the gun here....I looked at the 3/8-24 bolt that they send with the face mill and was comparing it to the larger bolt in my 1" arbor....I just checked it and found out that all my R8 arbors are 1" units.....drats....do you normally buy their arbors...looks like Enco doesn't have the Phase II arbors anymore.....they have ETM and their own brand....and range from $53 to $35...the Lovejoy is $80....
Old 07-01-2005, 10:21 AM
Check with your local tooling suppliers or go to MSC, Shop Tools etc for arbors.
Old 07-01-2005, 01:16 PM
My local tool supplier is kinda outrageous. I went with an ETM for $53 from ENCO...Lovejoy didn't call me back...so I suspect they went "on holiday a bit early."
Old 07-01-2005, 01:51 PM
Moderator
MikeAber is on a distinguished road
Typically shell mills do not come with arbors unless you specify them.
You will love the 205 face mill. Mine has been fantastic.
Old 07-19-2005, 08:27 PM
machiner11 is on a distinguished road
LoveJoy makes great milling tools. They probably buy the arbors though and resell them. I have been to the LoveJoy plant. They are one of the last plants in the world that can make real big face mills. They didn't call you back because they are very arrogant and not customer friendly, unless your name starts with GM or Ford.
Thanks,
Dave
www.kodiakcuttingtools.com
Old 07-19-2005, 11:54 PM
Well Bob Morris from Lovejoy always calls me back....sometimes their applications engineers are a bit slow, I suspect because they are swamped.
R2E3 Tooling dfmiller Bridgeport and Hardinge Mills 16 05-29-2005 05:51 PM
Where do you buy tooling? NeoMoses CNCzone Club House 8 10-08-2003 07:21 AM
Tooling ? CNCadmin Benchtop Machines 11 08-07-2003 07:06 AM
Help on tooling DanFri DIY-CNC Router Table Machines 4 05-02-2003 12:37 PM
custom tooling CNC Pro OneCNC 2 04-11-2003 11:36 AM
