Hey guys, been lurking here for a while, anyways I have to machine about 60 12' 1 1/4 sq ss bars. I can only machine 18 inches at a time and the bar is supported on the mill over 22 inches the rest is hung over the machine on roller stands. Ive been on this project for the last week and a half and finally got down to cutting. Well short progress and were already through a pack of inserts which is equivalent to 10 tools and about three bars done (but have to be rerun to fix the finish). Im pretty sure its my cutter that is causing me grief but wanted to get other opinions before throwing more money away in inserts. Im running a 3/4" 2Fl indexable end mill Im running it at 3005 RPM 107IPM .0625 radial .1875 axial DOC no coolant compressed air at the tool.The chips look good slightly tinted but not blued or burned in anyway. I tried to get some temp readings with the infrared thermometer and I saw a peak of about 200F. Spindle load is 10% on a 30HP spindle. The cut is very loud though like the 2fl isnt the best choice. Im thinking about switching to a 3" face mill that uses the same 90 degree inserts that Im using now 6 of them hoping that the mass and increased flutes will help smooth things out. Ive attached a picture of the fixture on the machine, it is not complete there are 6 edge clamps that run down the length to clamp the bar. The profile of the bar in the picture is what I have to machine. I put a 3" hole in the wall of the machine to feed the bar thorough and leave the door slightly cracked on the other side. A friend of mine thinks sandbags or something similar on the overhang would help combat the vibration that might develop. Anyone with any advice please chime up, it would be greatly appreciated! |
| Hi, not 100% sure the tool failure or the grade of carbide you are using but if you are going through a lot of inserts on stainless I think it could be a couple of things. 1 - Because of the setup the work piece could be vibrating. Tougher grade of carbides deal better with vibration but wear faster and harder grades will wear better but are more brittle and may chip. If the inserts are chipping then use a tougher grade carbide. 2- If the inserts look like they are burnt which is common on stainless then I would slow down the spindle speed to reduce the insert surface speed on the material and increase the cut per tooth. This will reduce the stainless steels tendency to work harden and insure the insert are always cutting fresh material. Some more tool information, failure mode and even tool pictures could also help in your description of the problem. Good luck as stainless can be a pain!! |
| You are feeding that with just under .018" feed per tooth. Depending upon the size and design of the insert, that may be up to 2 times what you should be running. Your cutting speed of 590sfm is OK, as long as it's a good grade of insert for that material. If not a good match, that's a bit high. I think your bigger enemy of tool life is workpiece rigidity. If your photo shows how you're hanging onto this, I can't see how it's clamping the work. Perhaps you should try to add some additional clamping because from your description, things seem to be moving around. |
| Here are some more pictures of the setup, and some of the inserts. Also here is a link to the spec sheet for the inserts I am using. http://www.mitsubishicarbide.com/mmc...43g_200308.pdf I can feel a slight vibration in the unsupported bar while machining, but it didn't seem like anything to be alarmed about. I attributed it more to the fact I was using a 2 flute tool. I haven't had any problems with the workpiece shifting etc. The inserts are fine for a while then the spindle load will creep up 1-2% and you can usually hear a change in tone when a chip develops in the insert, so I stop the program replace and restart. I have the tool entering on a 1" radius 22.5 degree sweep I also think some changes in the entry exits could help prolong the tool life. This is my first big job with stainless and Im loosing my a** on it! |
| OK, so you're fairly secure in work holding. You are WAY overfeeding the insert if that data sheet is read correctly. Right there it says "0.2mm" as the mean, and "0.1 - 0.3" as the range. That's a max of .0118fpt to your .0178. If you can get the 6-insert cutter in there and lower the feed per tooth, you'll like the results much better. |
| I looked at the link you gave and it may be that I am interpreting the information incorrectly but it seems to me your inserts are behaving as they should. Part way down the page is a diagram showing Flank wear versus Cutting length which stops at a cutting length of 15m. What is your total cutting length, it must be comparable to 15m per insert given the shape you are making and the number of passes you do.
| Not the way I see it. The failure mode for the inserts is really hard to determine when you have catastrophic failure like that. What it should be is simple flank wear. What it is, is fracturing. We can't tell if there was plastic deformation, thermal cracking, built-up edge or any of the other common failure modes when the cutting edge is just blown away. |
I was looking at these inserts also hoping they are a better grade. http://www.mitsubishicarbide.com/mmc...5tf_200311.pdf |
#10
| The VP15TF grade just might work better, but what I'd look to for best performance first would be edge prep. If your current insert is showing any signs of leaving work-hardening behind, get a more upsharp edge on the insert. I don't usually see that much correction factor for chip thinning. Usually, under the depth of cut and width of cut you have there the correction factor would be about 1.3 to 1.4, while you are almost 2x. |
#11
Is there an easy way to tell if Im work hardening the piece? |
#12
| The only way I know visually to check for work-hardening is color change. I'f it looks like heat got into the workpiece (instead of the chips, as is supposed to happen) you'd see a tinge of a bronze/straw color in 304. And you'd have fast-dying inserts. |
| Is my BMC-40SLV toast? | parkerbender | HURCO | 7 | 08-06-2010 12:19 PM |
| my 2 speed motor is toast, I think... | solarguy | Bridgeport and Hardinge Mills | 2 | 06-27-2010 08:52 AM |
| Newbie- What is the difference on 321 inserts?? | wrechin2 | General Metalwork Discussion | 13 | 01-18-2009 01:15 AM |
| Error 14-How to reset?/or is my VFD toast now.... ? | Rich05 | Phase Converters and VFD | 12 | 09-22-2007 02:57 PM |
| CN0142 is toast? | ejholmgren | Gecko Drives | 1 | 12-08-2006 02:26 AM |
