Old 11-03-2010, 10:31 PM
webgeek is on a distinguished road
Raising up a vise
Hi all; I have a pair of 8" Kurt-style vises that I need to raise vertically around 3 or 4". This is a really silly question, but what's an in-expensive way to do that? I've not really found anything cheaper than about $50 an inch of height - 12 x 12" plate steel in that case. Accuracy is not much of a problem in this case so it doesn't need to be a super flat material. It needs to be something that can handle coolant and be there for a reasonably long time. Any suggestions? I was shocked to find that it would be so expensive to lift the vises. Thanks in advance!
-Mike
Old 11-03-2010, 11:46 PM
You don't need to have a completely solid chunk of steel under the entire area of the vise. Just spacers about 1-1/2" dia under each bolt (or clamp) location.
Old 11-04-2010, 01:26 AM
Cruiser is on a distinguished road
a quick and easy would be to get a length of rectangle tube of 1/4" wall and put slots in it for vise keys and put holes in other side to key it with pins to align it to table. If need you can mill sides flat for a little bit better lay. Or buy some 2x4x6 blocks.
Don
IH v-3 early model owner
Old 11-06-2010, 08:31 PM
roninB4 is on a distinguished road
It would really depend upon what you're doing and how large an area you're machining in the throat opening. If it's some light detail milling and some drilling then you really don't need much under the vise. As the other posted suggested, some risers that are 2" OD will handle drilling just fine. If you're milling, taking some fairly heavy cuts then the vibration may be too much for the reduced contact area of a 2" riser. You'll need more contat area to transmit the vibes to the table. At some point, more contact area will not help because you're machining too far up off the table. Without knowing the particulars it's difficult to advise what will help you best per dollar spent. Mass helps, but will not overcome the limitations of dull tooling, too large a cut, or excessive play in the machine ways. Vague questions generate generic answers.
Old 11-07-2010, 11:48 AM
BobWarfield's Avatar
BobWarfield is on a distinguished road
246's are super handy to have around, and as mentioned would do the trick.
Enco or someone will have them on sale sometime soon if they don't already.
Cheers,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
Old 11-07-2010, 12:26 PM
awemawson is on a distinguished road
Why not mount it on a slice of RSJ (universal joist) ibeam or whatever. Or weld up a weldment
AWEM
Andrew Mawson
East Sussex, UK
Old 11-07-2010, 05:50 PM
corndog67 is on a distinguished road
I've used those chinese 2-4-6 blocks, although when they are on sale, it costs more to ship them than it does to buy them!!!
Old 11-07-2010, 08:49 PM
ROFL!
That's why we like Enco's free shipping.
Cheers,
BW
Raising Taig headstock MechanoMan Taig Mills & Lathes 9 04-14-2009 04:29 PM
Gibbs Raising Maintenance Fees 23% Rocko1 GibbsCAM 9 07-06-2008 03:43 PM
Raising Voltage from 12 to 24v Marcvw79 Hobbycnc (Products) 1 03-11-2008 05:29 PM
Keeping your zero when raising the head wcarrothers1 Benchtop Machines 11 02-10-2007 12:37 AM
Home Made Vise Stop - For 6" Kurt Vise widgitmaster Bridgeport and Hardinge Mills 20 12-15-2006 08:49 AM
