Old 10-31-2010, 09:02 AM
ngwanhoe is on a distinguished road
Spindle Speed
I notice that the mini milling machine can change gears.
Spindle speed: Low range 0-1100rpm /- 10%. High range: 0-2500rpm /- 10%.
I know that drilling hard material or large drill bits use low speed and soft material or smaller bits can use high speed.
But why need to change gear as the high gear range is 0-2500rpm?
Confuse.....
Old 10-31-2010, 01:30 PM
Torsten's Avatar
Torsten is on a distinguished road
As with all electronic variable Speed setups you will loose Horsepower as you slow the motor down. This can stall the motor as you try to put some load on it.
A mechanical gear setup will allow the motor to run closer to its rated rpm where it can supply the horsepower as stated on the nameplate of the motor.
So when running slow the lower gear will give much more power to drive your tool.
Of course some tools do not require much power and will run fine even with the higher gear setup.
Old 10-31-2010, 08:02 PM
Thanks Torsten,
Ah... I understand a little bit now. That means if I were to drill a large hole with larger drill bits, the low gear provide more torque and would not jam and stalled in the hole.
Cheers
New Machine Build- Spindle speed davidbhewes@com WoodWorking 3 05-28-2008 11:51 PM
Spindle speed not 100% AndyB Fadal 6 07-13-2007 08:52 PM
Spindle Speed teenrocketnerd DIY-CNC Router Table Machines 1 06-20-2007 05:59 PM
spindle speed Mike Boarman Machines running Mach Software 0 11-27-2006 09:37 PM
BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? peter.blais Bridgeport and Hardinge Mills 9 08-08-2006 03:29 AM
