Old 10-30-2010, 04:42 PM
ServoGuy is on a distinguished road
Question Tiny Holes, Lots of Em!
Hello,
I have a bit of a technical question here.
I plan on making a good number of parts that have a lot of tiny holes in them,
and it is absolutely critical that I get no bit breakage per part. A bit stuck in the part would ruin it completely, and tragically that happens more often then not.
I would like to know what the best feeds and speeds and RPMS for the following:
I plan on using peck drilling, G83 I think. The tiniest bit is the one I am having the most trouble with.
Material: Brass, yellow.
Drill: 0.028 (HSS, unless it would be better for something else)
Depth: 0.375"
Number of holes: 72
Drill: 0.042 HSS
Depth: 0.375"
Number of Holes: 36
Drill: 0.0625 HSS
Depth: 1"
Number of Holes: 36
Machine: Tormach PCNC 770,
Flood Coolant - the blue stuff
I have tried with the tiny bit 0.5IPM feed, 0.02 Peck, 2400rpm, full retract
Works, sometimes.
Any help would be greatly appreciated!
Old 10-30-2010, 05:41 PM
Yellow brass can be a bit of a problem with standard helix drill because brass tools should have zero top rake and the cutting edge on a drill doea have top rake due to the helix. On larger drills it is possible to hand grind a small flat on the edge to get zero rake and this helps but you would need a steady hand on the size you are using.
You may be able to get drills intended for brass with a reduced helix.
Old 10-30-2010, 05:56 PM
neilw20's Avatar
neilw20 is on a distinguished road
Run faster maybe.
I would think maybe 4000 or more.
Then the 0.5IPM will be closer to right.
Imperative to spot center first. If not spot on, the drifting drill will break.
I do spot centering with the same program, but just use Z-inhibit to limit the depth with the center drill.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 10-30-2010, 06:06 PM
packrat is on a distinguished road
You don't really need to use a grinder to blunt the lip edges of the drill, using a stone and giving a few swipes on each lip is enough on small drills like this.
cary
Tags
cnc mill, drilling, feed rate
Tiny THK Bearings lockie Linear and Rotary Motion 1 07-24-2010 07:57 AM
problem drilling tiny holes gilessim Steam Engines 7 05-26-2009 05:04 PM
RFQ: A tiny job in Europe dosign Employment Opportunity 3 01-28-2008 06:42 AM
wee tiny endmills project5k Metal Working Tooling 6 09-25-2007 08:13 PM
tiny linear rails elninio Linear and Rotary Motion 2 06-25-2007 05:25 PM
