I am working on a simple shaft coupler for connecting a large electric motor to another shaft. I need to bore the coupler to slide nicely over the motor shaft. My problem is I do not have the motor in my possession to just machine it to fit. All I have is the drawing of the motor. http://www.go-ev.com/images/003_09_0...ng_Drawing.jpg The sheet shows the DE end shaft diameter between 1.245 to 1.250. So what I am looking for now is an idea of how manu thousandths I should over bore the hole for a nice fit. I will broach it with a .250" wide by .125" deep keyway for locking to the shaft. I will add a set screw to the back side of the key to create clamping force on the key face. Any ideas? -Adam
__________________ www.adambrunette.com - Converting My Harbor Freight X2 And My Jet Jvm-830 Knee Mill, As well as many other projects. |
| Thank You. That was the answer I was looking for. I was thinking like .003 to .004 would be good, but wasnt sure. -Adam
| Hi To me there would seem to be a mistake on the drawing. If you look at the shaft at the other end of the motor it is dimensioned as 0.8750 to 0.8745 or in other world a 0.0005 span, which is what I would expect to see on a motor shaft. The 0.005 tolerance is excessive and means that a nice sliding fit can not be guaranteed. If you then take in the 0.003 clearance suggested you could end up with a 0.008 rattle fit rather than a slip fit. I would suggest that the size on the drawing should read 1.250 – 1.2495. I would aim for 1.250 -0.000 +0.0005 or +0.001 at most, on the bore which would give you a transition fit Regards Paul |
| Bit Slip on Chinese Spindle | analogman | DIY-CNC Router Table Machines | 4 | 12-05-2009 04:23 PM |
| "D10"tolerance on a bored hole | jkford96 | Mechanical Calculations/Engineering Design | 10 | 07-14-2008 12:48 PM |
| Non-Slip Material | scratch_6057 | CNCzone Club House | 0 | 06-16-2006 08:47 AM |
| Non-Slip Router Mat | chuckknigh | DIY-CNC Router Table Machines | 4 | 01-20-2004 11:25 AM |
| Forcing overcut | HuFlungDung | OneCNC | 2 | 06-10-2003 05:43 PM |
