  #13   Ban this user!
Old 06-28-2005, 01:03 PM
ViperTX is on a distinguished road
You have to mask off where you don't want the solder mask to be applied....I believe there are some hobby spray on options....before long..you'll find it cheaper to prototype the layout then have some make the PCB for you.
  #14   Ban this user!
Old 06-28-2005, 03:08 PM
JRoque is on a distinguished road
Hello. I agree with Viper. The principal benefit from milling your own PCBs is speed and cost of using the already existing CNC machine. However, the benefit curve quickly turns toward outsourcing when you get into more complex areas like having to soldermask, silkscreen or multilayer a PCB. But half the fun is trying to condense your circuit into a single-sided layout and soldering an MLP chip without a mask.
JR
Having trouble cutting aluminum sheet fastturbovet General Metalwork Discussion 40 06-14-2005 10:33 PM
PCB milling FabCNC General Metalwork Discussion 5 05-24-2005 07:44 PM
pcb milling dberndt Employment Opportunity 3 01-03-2005 08:44 AM
Where to buy CHEAP PCB milling bits abasir General Electronics Discussion 12 04-17-2004 09:14 PM
Cutting tool shape for PCB milling NeoMiller General Metal Working Machines 2 11-13-2003 11:09 AM
