I'm interested in tooling up to do single-point thread cutting on my Taig mill, and thinking that an indexable insert system makes the most sense, but am a little bewildered by the variety available. One of the projects that I have in mind is to make a new Tr12x1.5 lead nut for my garage-sale chinese 3-in-1 lathe. Are there any insert systems that can thread a bore as small as 10mm? |
| smallest I've done was a 3/16 two start 20 tpi, just under 5mm. That's a coarse small thread for single pointing! It worked but was a nail biter. Easiest way to tool for it is make it from drill rod and heat treat. You can turn the tiny 60 part as a profile then file/mill away what you don't need and file relief. If you've not made a cutting tool before, its much easier than it sounds |
| Single point threading (lathe) with EMC | chafik | LinuxCNC (formerly EMC2) | 2 | 06-07-2008 06:04 PM |
| Using the Mill as a Lathe; Single Point Threading | Geof | Haas Mills | 10 | 02-07-2008 01:28 PM |
| Single point threading | DragnsBane | General Metalwork Discussion | 2 | 10-05-2007 11:25 PM |
| Single Point Threading Inserts | John3 | Polls | 1 | 08-06-2007 09:45 AM |
| Single point threading | kdoney | Mach Mill | 8 | 02-08-2006 11:13 PM |
