Old 10-20-2010, 06:32 AM
brandon2010 is on a distinguished road
Graphite Plug install
has anyone installed Graphite plugs before into aluminum bronze?
we are doing it for a custom wear plate
we will be using 1/2" dia plugs
we are planning on just using a bit of loctite and press fitting in the plugs?
is there any tricks to do it?
thanks
Old 10-21-2010, 11:18 AM
plastibob is on a distinguished road
thanks
Where did you get the graphite plugs?
Old 10-21-2010, 11:50 AM
we are getting a 1 foot long rod of graphite at 1/2" round that we will be cutting approx 3/8" long to put into the aluminum bronze
Old 10-21-2010, 01:31 PM
keebler303 is on a distinguished road
I don't know if loctite would be a good idea. It might turn gooey when the bushing gets hot and muck things up. Maybe you could heat the bronze up a bit and shrink fit it to the graphite. The graphite does not need to be held very well because it will be captured once its installed. You just need it to stay in there long enough to put it together.
Matt
Old 10-21-2010, 05:46 PM
packrat is on a distinguished road
Hope that your using a bearing grade graphite, not a EDM electrode type graphite. The EDM graphite is abrasive/hard, not like a bearing grade.
machining graphite davidsutton Composites, Exotic Metals etc 24 04-25-2011 10:07 AM
Unplugged Spindle Fan on 2006 VF2, cant remember which plug to plug it back into.. locash Haas Mills 2 08-20-2010 12:41 AM
CNC Hardmilling/Graphite tungwenuk Deckel, Maho, Aciera, Abene Mills 1 02-21-2010 11:51 AM
Graphite blocks davidmb EDM Machines 3 01-21-2010 03:09 PM
EDM Blanks Graphite SPEEDY1977 CNC Plasma and Waterjet Machines 1 02-09-2007 01:35 PM
