I have gotten some Yaskawa SGMG-30A2ABS motors and SGDB-30ADG drives Hoping I can score some of their smaller motors (as I'll admit the 30 is quite big at 18lbs but would make a nice long axis motor) Anyway the issue with the 30 motor is it's output shaft is 35mm. Need it down to around 22 or 24 mm to interface with my next biggest gear reducer. Wondering if anyone has any experience in altering the diamerter of servo motor shafts or if it's even really possiable. I'll probably end up just leaving these for when perhaps I retro fit my bridgeport but who knows they might end up on my current 10x5' project.. b. |
Step 1: machine up very carefully an extension tube to go over the 35 mm shaft. It needs to be a very close fit. Or use a very large parallel-shaft collet chuck. Step 2: mount motor on bed of lathe at headstock end, align carefully with bed. Use dial gauge for both horizontal and vertical deflections with extension piece made in step 1. You do not have to be on the headstock axis. Step 3: power up servo motor and turn shaft down. Gently and carefully. Cheers |
| The way you turn down servo shafts or any motor shaft for that matter is to take the motor apart, ( after all is was in pieces before assembly at the factory ), Put "keepers" in the stator to prevent magnet losing power, setup rotor true in lathe and perform desired machining. Reassemble. I have done many, many, motor shaft modifications and never with the motor assembled. You'll never get it true or even rigid enough to machine. |
In some cases it may even be possible to chuck one end of the motor shaft and hold the other end with a live centre. Have to stop the motor from spinning!!!! But this can work very well. Using a tool-post grinder is possible of course, but many people worry about getting grit into the bearings and ways. It all depends, as usual. Skinning cats ... Cheers |
| wcarrothers1 Thats a big motor, would be more suited for your 10'X5' machine build, I would try not to change the shaft, you could make a coupling for the motor with a flange on it, you can then bolt any size timing pulley to the flange, turn a step on the flange to locate the timing pulley
__________________ Mactec54 |
| Cheers |
| Servo motors have permanent magnets in them, you take out the rotor and put "keepers" in the stator to prevent loss of magnetism. He's going from 35 mm down to 22 or 24 mm - how long do you think it's gonna take him to grind off 11 to 13 mm, all morning maybe? c'mon people let's think a little. |
#11
| maybe you should let the world know about this ,there's whole company's out there braking your rules , getting work done , making money grinding all types of parts removing a s@&t load of material by grinding |
#12
You might also consider the guy is asking how to reduce a motor shaft for a retrofit,hardly a company with a grinder capable of doing it in a reasonable time at a reasonable cost,so,only an idiot is going to suggest grinding. |
| couple of sets of Indramat Servo Controller+Mains filter+Servo Motor 9Nm, 4500rpm | bogus105 | EBAY ADS | 2 | 11-16-2011 10:25 PM |
| Need Help!- Changing Fanuc AC servo driver and motor for a regular VFD and async motor | Bordaco | Servo Motors and Drives | 4 | 09-08-2011 05:41 PM |
| Got my MR-J2S40 Mitsubishi servo drives turning and a few questions.. | CncForMe | Servo Motors and Drives | 120 | 08-22-2010 04:37 PM |
| Sell Servo Motor, Servo Drive by GSKcnc.com from China | salecnc@hotmail | Product Announcements & Manufacturer News | 0 | 06-03-2008 02:55 PM |
| Request for Help, Motor not turning | sdantonio | Stepper Motors and Drives | 3 | 03-16-2007 11:53 PM |
