Old 06-23-2005, 10:00 AM
Deviant is on a distinguished road
Q: Best way to cut small oring groove?
What is best way to cut a 1mm o-ring groove to a .75mm depth on a mini lathe.
I'm considering using a small drill bit. Is there a better way to do this?
The machining adventure continues. = )
Old 06-23-2005, 12:31 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
OD or face?
What's the material?
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 06-23-2005, 12:43 PM
psychomill is on a distinguished road
HUH????
Old 06-23-2005, 12:50 PM
anoel's Avatar
anoel is on a distinguished road
Originally Posted by psychomill
HUH????
Exactly...
Grinding an appropriate form tool is the correct way to do it...
Nathan
Old 06-23-2005, 01:12 PM
Gold Member
Ken_Shea is on a distinguished road
Grind the desired width into a cutter, I have found that it does not have to be round just grind the end square and chamfer the outside. Here is a picture of one ground for a inside. It is looking down from the top, of course a relief has to be ground on the underside.
Old 06-23-2005, 02:04 PM
mxtras's Avatar
Silver Member
Ken -
Based on the uniformity of the burn marks, that tool looks EDM'd to me....you cheater!
Deviant -
I have frequently used a part off tool for OD grooves since it eliminates a lot of grinding.
Face grooving tools for small diameters require either a lot of attention or a very frail cutting edge. Let us know if you need some pointers.
Scott
Old 06-23-2005, 02:05 PM
It's on the outside of the of the piston...
I was considering using a broken drill bit, ground flat. Similar to how people use them to make a boring bar. I was just going to make a 1/4" clamping fixture to hold the bit in my tool post.
Grinding a 1/4" tool bit down to less than 1mm is going to be interesting...
Maybe I'm over thinking it.
Old 06-23-2005, 02:24 PM
Gold Member
No EDM here, just a cheap grinder and about 20 minutes
Old 06-23-2005, 02:38 PM
mxtras's Avatar
Silver Member
.....ground by hand - what-everrr (in my best SoCal female voice). It's your story - tell it how you want.
(J/K!!!) - I am in a goofy mood - painkillers are a guud thing!
Good work, Ken. Your patience is obvious. Looks really good.
Scott
Kcam Cut depth 47MLB Kellyware CAM 6 01-18-2012 02:04 PM
cutting oring groove fastolds BobCad-Cam 4 06-17-2005 03:26 AM
cut single, cut auto and cut all??? fastolds BobCad-Cam 3 10-06-2004 09:15 AM
PICS - BOAT HULL CUT WITH CNC ninewgt DIY-CNC Router Table Machines 16 08-02-2004 07:21 PM
