#13
| i can find 1/32 with 1/8 flute length...that seems to be 'long' for that diameter. 1/16 i have are about .3 long (just measured) until now i had been able to find mixed sets on ebay for as little as 10$ for 25 (drills and mills - microsize) but those seem to have long vanished...now i'm just getting my head around the idea i have to pay 3 or 4$ or more for a cutter...good thing i had the cheap ones to learn with. finding cutters is no problem - finding cutters that one can afford IS a problem i'm trying to solve without a lot of success - i've looked hard! i'm sooo not done learning how not to break em! |
#14
| Here is a Canadian link http://www.carbide.ca/prod.html?id=9 Here is A USA i think 1/16 X.250 http://www.gravers.com/s08cut7.html |
#15
| those micro bits i was talking i got from grizzly or harbor freight been awhile its a set of like 25 bits and was like real cheap some of the bits i have had no use for ....yet ...but they are there if i ever need em so muti bit types micro sized (.0xx) |
#16
| those micro bits i was talking i got from grizzly or harbor freight been awhile its a set of like 25 bits and was like real cheap some of the bits i have had no use for ....yet ...but they are there if i ever need em so muti bit types micro sized http://www.harborfreight.com/cpi/cta...emnumber=44924 like $5 for 20 or they have a 50 for $12.99 |
#17
yeah buddy! watch me click for a ton of those suckers right now! even if i use but 3 bits of a set, i'm doing great! thanks a ton for sharing that link! done- got 10 sets of 50 comin! thanks again strat! Last edited by gcz; 06-23-2005 at 03:52 PM. |
#18
| The smallest ones that I've ever seen have been dental burrs. The ones that the dentist uses to drill into your teeth with. ![]() There are two types, diamond and carbide. Use the carbide ones, they look like miniture mill bits and come in a variety of shapes and sizes. They have a 1/16" shank on them. Due to their small size your feed rates won't be the fastest. I have used them before in all types of material (wood, plastic, metal and glass). Google up "dental burrs" and you should come up with something. I have seen them for less than $1 each. Ask your dentist to save some of his old ones for you so you can try them out.
__________________ If it's not nailed down, it's mine. If I can pry it loose, it's not nailed down. |
#19
| Great link. So if I wanted to cut 1/4" deep or maybe a little more, since the flute is 1/4" is there a straight piece of carbide right after the flute at the same diameter before it tapers into the shank diameter? Thanks. |
#20
| I use Micro100 Endmills on our Citizens... Small tools are Micro100's nitch... http://www.micro100.com/cgi-bin/Inch.cgi/?Prefix=GEM For a very small endmill I usually would make small, light cuts.... 3000-4000 RPM depending on the SFM it recomends, and 1-2IPM. My DOC would be somewhere in the range of .020-.080 depending on the material. You can obviously cut Mag/bronze and aluminum easier than you can cut stainless... :-) |
#21
| Does anyone has Smallest Jet engn.Plan ? | Calico | Jet Engines and Ram Jets | 7 | 03-21-2007 08:26 AM |
| RFQ: 12/13 guage stainless disks, 2" diameter | InspirationTool | Employment Opportunity | 4 | 10-08-2006 09:18 AM |
| Drill Rod Diameter Recommendations | grempel1 | CNC Wire Foam Cutter Machines | 6 | 11-19-2004 09:28 AM |
| Can you soak endmills in oil,for storage? | sendkeys | General Metal Working Machines | 3 | 11-15-2004 09:09 PM |
| Ball screw diameter | samualt | DIY-CNC Router Table Machines | 2 | 01-02-2004 06:00 PM |
