Old 10-01-2010, 02:59 PM
Species8472 is on a distinguished road
Offline Tool Presetting Management
We have a new tool presetter that will generate a G10 line program to upload the tool gauge line to the cnc. I need a system to organize tool numbers. 5 4axis machines with two plates each so i never know what tool numbers are in use at the time of setup. Any ideas?
Old 10-01-2010, 10:37 PM
christinandavid's Avatar
christinandavid is on a distinguished road
I program T numbers as variables ie from #101 onwards. These are then defined at the machine in a local sub program, so you could standardise your G10 outputs in this way...
In fact I also do something similar with my work offsets. It makes life a lot easier with a twin-pallet which is constantly running overlapping small batch operations. Every run we do results in a different configuration and this method provides ultimate safety and efficiency.
The undesired effect of this is that the 60 tool magazine will usually fill up before we can be bothered to start removing any set tools much to the annoyance of the tool man.
DP
Need Help!- management of tool life hongjianming CNC Swiss Screw Machines 2 07-28-2010 11:41 AM
Renishaw tool offset / break probe and tool life management mcash3000 General CNC (Mill and Lathe) Control Software (NC) 0 02-20-2010 09:14 PM
Need A Quote- tool life management oskar the 2 CNCzone Club House 1 05-19-2008 08:51 PM
Problem with Presetting tool Man@Work Daewoo/Doosan 3 02-22-2008 12:31 PM
Need Help!- tool presetting Doug Tyler CNC Tooling 0 02-17-2008 08:29 AM
