Getting some 4340 in for a project. I know what I can comfortably run 1018 for feed/speed. Thinking somewhere 1/2-3/4 as fast for the 4340? The 4340 Im getting in is pre treated, ~30 RC. Im going to have it annealed down to ~15 RC. This is all milling, making better than 1/2 the part into chips. Running indexable face mill, end mill, etc. I run a 2 flute 1" cutter at 25 ipm, at 2200 RPM now, .250 depth, at ~50-60% spindle load in 1018. Thinking back down to ~1800/20ipm/.200 for the 4340? Other suggestions? |
| Why get pre-heat treated then anneal it? Your just paying for a throw away heat treating. 30 Rc isn't all that hard. I believe your pre-heat treated 4340 is closer to 34-38 Rc and that is machinable. A bit stiffer than 1018 though.LOL Dick Z
__________________ DZASTR |
The material being pre-treated is just what I happen to be able to find for the size I need. That, and Im pretty sure I can take care of annealing myself, in small batches. Ive got a small oven. |
| I agree with Rich, 4340 machines quite nicely at 28-32 (pre-heat) HRC, there really is no reason to anneal. It will actually finish better in the pre-heat condition. Let's also not forget, your time is never free... at least it shouldn't be. Very general guidelines but, you will probably machine at 65-70% the rates you're seeing in 1018. Solid carbide end mills; 70-170 sfm for slots, 125-225 sfm for peripheral cuts. Use the high range for lighter peripheral (~.1D) and the lower range for heavier cuts; same for slotting. I don't know your part geometry but if you really want to get serious about MRR in this material, look to hi-feed mills. The Mitsubishi AJX and Hitachi ASR are two of my favorites. Speeds will be in the 350-550 sfm range, 120-300 in/min dependent on axial depth. A 1" diameter hi-feed can easily achieve 2.75-4.5 in³ in 4340 at ~30 HRC. For the tooling you have, really need to know what you plan to use. The more info, the better. Regards, Chuck
__________________ The Manufacturing Reliquary http://cmailco.wordpress.com/ |
| who wants indexable tooling for their pc 892? | spoiledbrat | Polls | 3 | 04-14-2010 01:10 AM |
| CRS 1018 Tooling Help | fhadk | General Metalwork Discussion | 6 | 11-06-2008 02:03 PM |
| Indexable Tooling | Erlock | General Metalwork Discussion | 4 | 09-07-2007 09:50 PM |
| Indexable insert tooling for newbies | Dan S | Mini Lathe | 11 | 12-30-2006 05:02 AM |
| Indexable tooling | Davidimurray | Mini Lathe | 2 | 11-18-2006 09:46 PM |
