Good morning all. I'm trying to convince someone that a small CNC is a better idea to turn threads than a manual lathe. What would be a reasonable ballpark time for cutting 1 1/4-8 threads 10 inches long from 1018 or similar? Does this kind of job need CAM or will a controller have the smarts to do it? Thanks. |
| how long are your threads? is this just a threaded rod (all-thread)? how many will you be making? if its all thread, you should look into a thread roller tool for your manual, you will save tons of time. if its just threads on the end of a part that has a shoulder or same diameter as the thread, cnc might be the way to go IF, and i repeat IF, you have a nice run and will continue to have runs. CNC's are a plus to have when your jumping from setup to setup on different types of threads, but if you only gonna make a few parts, it doesnt justify the cost. |
| Having cut threads on big and small manual lathes and big and small CNC lathes I can tell you CNC is much faster. For the diameter and length you give it would probably be faster to do a single one by CNC than doing it by hand, and this would involve handwriting the G-code for the threading. Actually cutting 1-1/8" - 8 on a small manual lathe would be a challenge because the width of the flank is so large most small machines would have difficulty driving the cut. CAM would not be essential to cut a thread like this. CNC lathes normally having dedicated cycles for threading which just require a few dimensions to be entered.
| I'd say around 5 minutes once you have a good program. Could be faster depending on the machine. If your used to threading on a manual lathe watching a cnc thread is pretty cool since on a manual you'd thread that around 50 rpms or so & cnc you can crank it up. Prob 500-1000 rpm depending on your max machine feed travels. |
| Formula for calculating RPM? | SSfab | Mechanical Calculations/Engineering Design | 28 | 03-28-2012 09:18 AM |
| Need Help!- long time reader first time poster | blu333 | General Metalwork Discussion | 0 | 02-21-2010 05:30 AM |
| Help calculating power please? | Oldmanandhistoy | General Electronics Discussion | 20 | 05-30-2007 10:00 AM |
| milling time (not to be confused with hammer time) | barefoot0 | G-Code Programing | 4 | 05-02-2007 06:18 PM |
| X2 Conversion Time (shopping time) | Micro Rotors | Benchtop Machines | 2 | 03-04-2007 11:11 AM |
