Old 09-20-2010, 03:38 PM
Rich05 is on a distinguished road
Where to find 30 degree dove tail cutter?
15 degrees on each side, for cutting aluminum, with a blade around .75 preferrably but shorter ok, has anyone seen one of these available. I cant afford to have one made custom.
thanks
R.
Old 09-20-2010, 03:56 PM
Andre' B is on a distinguished road
Was just looking for some dovetail cutters and had the Harvey tool catalog open.
Largest they have listed is a 30° included angle cutter, 1/2 diameter, 5/16 length of cut, $108.00, part # 16532.
If nothing else drill & ream a hole in the end of a 3/4 bar at the 15°, put a few set screw holes in it. Put a length of high speed steel in the hole and spend some time at a bench grinder putting a cutting edge on it.
Verify and Backplot withDove tail cutter foxsquirrel Mastercam 12 06-25-2010 10:55 PM
Looking for a 55 degree dovetail cutter darrylg General Metalwork Discussion 2 06-12-2009 07:18 AM
Need Help!- -AN/ 37 degree inverted Flare milling cutter kwmkoester General Metalwork Discussion 0 06-04-2009 11:02 AM
Enco's NEW Dove tail column Drill-Mill! HomeCNC Benchtop Machines 8 10-04-2008 12:14 PM
How do I use a dove tool cutter & slot cutter bobby1 BobCad-Cam 2 04-15-2008 08:06 PM
