Hi everyone, I have a hss 3" dia, 32 teeth, .125" thick slitting saw. The saw is staggered tooth and had side-milling on every other flute. I am going to cut a slot in a part that is made from 12L14 steel with a flood of coolant. The slot is about 1" DOC, at the deepest, on a 1.5625" radius. Therefore the cut is not very long, maybe 1.5" long. I am just wondering what i should be running for feeds and speeds? Also climb or conventional cut? Multiple passes or full depth? Thanks for the help in advance. Very much appreciated! |
| 100 sfm is very conservative and safe, 130 sfm if you plan to stay on the lower side of the cutting depth. That said, I'd go with 130 sfm and 4 passes or .250 radial depth per pass. Go .0012-.0015 inch/tooth... again, use the lower side for deeper radial, higher side for lighter radial. The chips should be no darker than a light straw color. 12L is a nice cutting material, pretty easy on saws... unlike many other materials. edit: Conventional milling Best regards, Chuck
__________________ The Manufacturing Reliquary http://cmailco.wordpress.com/ |
| Need Help!- How would you part piece of 12L14? | tikka308 | Benchtop Machines | 11 | 11-24-2009 03:00 AM |
| Does 11L17 machine as well aas 12L14? | Vern Smith | Haas Mills | 9 | 06-19-2009 04:40 PM |
| Good, Easy to machine Steel (not 12L14)? | Builder4wd | General Metalwork Discussion | 7 | 09-24-2006 09:33 PM |
| Best price on 12L14 round steel? | Joe H | General Metalwork Discussion | 4 | 08-09-2005 11:23 AM |
| Locating 12L14 | Ken_Shea | General Metal Working Machines | 4 | 08-10-2004 08:01 PM |
