the cavaty is aprox. 2.5" deep if not a little deeper and only 3"x2.5" wide/tall. |
At 2-1/2, it won't be that bad depending on what the actual feature is. I have a part with a slot at .150 deep on the floor next to a wall at 3.300 tall. An 1/8 em cuts it thats 5.0 OAL.
I would assume some sort of messuring tool to get the TIR very low??? what else??? |
Just indicate the tool like you would a drill/reamer. But, do it at two points. One at the holder end of the tool shank, one at the cutting end. An ER style holder will work best for small shank/dia tools. I use Bullseye and VC holders from
Lyndex/Nikken mostly. These holders are deadly accurate. Your spindle condition will affect your speed as well. If you have some runout or vibrations, you won't be able to run the higher speeds. You can still do it, just slow down.
I would have expected you to buy a 3/16 blank, and possible bring it down to the taper size you need. Thus a little more rigid than a straight cutter. |
Tool design is important. Number one: avoid long LOCs. Just because the feature is 2-1/2 down, doesn't mean you need a 2-1/2 LOC em. Use "necked back tooling". To see what I mean, check out Dataflute,
Destiny Tool ,
GW Schultz ,
Hanita etc. Even SGS and Niagara makes them. If you can get away with a little more shank dia, do so and get one custom ground. The 1/8 I'm using has 3/16 LOC, necked back to 2.70 (theres a step at the top of this wall), then into a 3/16 shank. Get as much shank as you can in there and keep the LOC short. For aluminum, use a 45 deg helix. The standard type helix is a little tougher, but it will more than likely "walk" on you. The helix will help it to keep engaged.
The best way I've found to do the machining is plunge mill the roughing, then profile or "slot". Keep the DOC short (20-30% of dia), axial to 50% or under. This isn't set in stone, just a starting point. You can get away with more, or have to go less depending on the situation. The 1/8 I'm using cuts between 6000 to 8500 rpm. But don't be surprised if you end up at 3000 rpm or less. You play with these things long enough, you'll get a feel for the running conditions. I can't give you exact speeds and feeds since the variables can change greatly. This type of machining has more curve balls than "how fast can I cut 304 with a 1" Carb hogger". Use your tolerance as well. Cut slightly big if you can and still be in print.
Why not EDM? For the most part, the feature is a small amount of detail. Maybe only a few of them at short depths. I can cut them faster on the machine in the same set up than having to unload the part, stage them at the EDM, set up the EDM and run. Thats if you have an EDM. If not, you have to pack, ship to an outside source, wait for them to run, ship back, unpack, check, etc, etc. It's a lot of added lead time.
1/16" gets a little trickier but the rules apply similarly. I have a 1/16 that reaches 1.80 dp, and just ran a 1/32 (actually ground to .029) that reaches .850 ( and sticks out from the holder at 1.35 on a 3/32 shank).
