| GHT thread I have a requirement to cut a 1-1/16 GHT (Garden Hose Thread), 11-1/2 TPI to fit a mating part. I have been unable to find any thread data for this thread. What is a good resource to lookup oddball threads? Even google lists many places that sell produts with GHT but I can not find any dimensional data.
__________________ Jeff If it aint broke, fix it till it is. |
| Well the Garden Hose Institute Of course... JK... Actually the Machinery's Handbook. They are listed as "ANSI Standard Hose Coupling Screw Threads".
| I looked in the Machinery Handbook and several other sources, they jump from 1" to 1-1/4" I can not find any indication that a 1-1/16 actually exists, except for the mating part to the one that I am making.
| Wow... Sorry I missed the 1_1/16" part..My bad.. :frown: I really don't know where to send you..maybe call a gage manufacture..and see if they have any info..or see if you can get your hands on a copy of the ANSI standard that is referred to in the Handbook..It might have other odds sizes listed..
| take a guess. its for your own stuff it doesn't have to be to a standard. and its a pretty good guess that if 1" and 1.25" hose threads have a pitch of .08696 and thread height of .05648 then the 1.0625" will too..if its an od thread use thread wire or in this case probably Pins and messure the pitch diameter. just a thought
__________________ thanks Michael T. "If you don't stand for something, chances are, you'll fall for anything!" |
| OK Plan 37 worked. I just set the lathe to cut 11.5 threads per inch and kept going deeper till the mating part screwed on, and called it close enough. Thanks
| Thread mill programming software? | cncwhiz | G-Code Programing | 6 | 12-31-2008 02:48 PM |
| Thread milling, can anyone help | jtrav | General CAM Discussion | 16 | 03-06-2006 03:25 PM |
| Hard-to-machine thread | tex | G-Code Programing | 30 | 11-04-2005 01:17 PM |
| for engraving pcb which is a good thread size for the lead screw? | NickLatech | DIY-CNC Router Table Machines | 11 | 01-17-2005 09:37 PM |
| Thread milling cutterdia / hole ratio | HuFlungDung | Machine Problems, Solutions , Wireless DNC, serial port | 3 | 12-31-2003 09:44 PM |
