Old 09-14-2010, 05:42 PM
J_REV is on a distinguished road
Machining a Right angle gear box out of 316 L
Any help I can get with regards to machining 316L. I've never done it before. Speeds and feeds would be helpful. I'm starting with a 3" block and right now it's not cutting well at all. Thanks
Old 09-14-2010, 07:14 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
J_REV, feel free to join the G-Wizard beta test, it's free and the Feeds and Speeds calculator will help you figure out what you need to do for your project.
Cheers,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
Old 09-14-2010, 07:21 PM
Cmailco's Avatar
Cmailco is on a distinguished road
Question
I'll assume you're wanting to get it done without a heavy re-tool, so why not tell us what you have at your disposal.
316L is not that difficult, though it can be gummy and does harden when cold worked.
What kinds of problems are you having and what speeds/feeds are you currently using? CNC or manual machining??
Thanks,
Chuck
The Manufacturing Reliquary
http://cmailco.wordpress.com/
Old 09-15-2010, 05:38 AM
I have no carbide drills and 1" and 3/4" soild carbide endmills. I also have a Kenametal inserted facemill KCM30 I'm positive on the inserts.I look later today. All CNC
Basic Bevel Gear - Milling a valley for gear teeth ngr1 General CAM Discussion 10 04-05-2012 09:55 AM
Gear Machining Software cjjonesarmory Mechanical Calculations/Engineering Design 2 07-12-2010 08:47 AM
machining angle for surface rough pocket for MC9 Chuck Reamer Mastercam 6 08-31-2007 06:39 AM
machining angle iron stymye General Metalwork Discussion 14 09-04-2006 12:43 AM
Right angle gear box info needed. danmickey DIY-CNC Router Table Machines 4 11-24-2005 04:18 PM
