Old 09-02-2010, 02:23 PM
Konstantin's Avatar
Konstantin is on a distinguished road
Flattening aluminum tube?
Hi.
Is it possible to flatten a 1 1/4" 6061T6 aluminum tube at one end, lets say I need a flat end centered about 1" to 2" long. Should annealing take place or its possible to cold work it?
How about 6063T5? I have this one locally.
How about buying 6061T0 and cold working it and then hardening it, maybe in some other shop, since I don't have a kiln. Is 6061T0 being sold?
My question may sound naive, I don't know much about aluminum, I have this idea of a structure I would make out of aluminum tubing.
Thanks for your input.
Old 09-02-2010, 02:55 PM
RotarySMP's Avatar
RotarySMP is on a distinguished road
Back years ago in the Airforce, I was in a skin bay overhauling A4K Skyhawk flight controls. We started getting delaminated rudders in, and tried to make flat sided oval Alloy tube out of round.
We tried annealed tube, filled with sand, and then pressed, but never got a good flat. There are some low melting point alloys which might work through.
You won't be able to cold work T6 much without it cracking. Do you have a drawing of the peice? Making things with flattened ends of tubes is seldom structurally efficient.
Regards,
Mark
www.wrathall.com
Old 09-02-2010, 03:30 PM
Konstantin's Avatar
Thanks for the input Mark.
This is an assembly of what I am trying to do, basically it is an umbrella mechanism, it is in the early stages and I am thinking of modeling a sheet metal hub that will hold to the ring and allow the assembly to slide up and down the mast.
While I was modeling it I was thinking "wouldn't it be easier to simply flatten the tubes instead of machining this joiner piece you see inside the tubes.
I am trying to get a cost effective solution to this as I do not have a milling machine, working 6061 T0 would be ideal and then hardening it, at least that is my fantasy.
Old 09-03-2010, 04:02 PM
RotarySMP's Avatar
How do you mount the flattened tubes onto the ring?
If the stresses a low, then flattening the end would probably work, but you would have to do it in 0 or W state, and then when you heat treat teh tubes back up to T6, they will likely warp all over the place (unless they are quite large diameter).
How many cycles will be required? The holes in the flattened alloy tubes may slog out pretty fast.
Try it.
Regards,
Mark
www.wrathall.com
Old 09-03-2010, 04:48 PM
Drassk is on a distinguished road
Would everything still fit if you epoxied plugs into the ends of the tubes and then drilled through the whole thing? As RotarySMP says, it seems like holes drilled through the walls of a tube might wear and warp really quickly.
You could make the end pieces with a bandsaw pretty quickly.
Old 09-03-2010, 06:48 PM
Konstantin's Avatar
I believe Mark is referring to the holes in the flattened tube, they will wear out, I think he is right.
Pehaps I should explore easier ways to machine the plugs as you say Drassk. Would it be an option to secure the plugs inside the tubes using only structural adhesives?
Which adhesive could it be?
The ring I modeled as a whole, but in reality I think I would use a stock bar of metal and coil it, then cut out and solder once the plugs are inserted on. The sheet metal hub I mentioned would wrap around the exposed parts of the ring like fingers.
Old 09-03-2010, 08:48 PM
MikeZee is on a distinguished road
Why use Allum ??? there has to be something lighter and more "moldable" to suit your application.
Old 09-03-2010, 11:21 PM
Konstantin's Avatar
Hi Mike.
Like what for example?
The structure is intended is for a fold able recreational vehicle that will support 1 person. 6061T6 naturally comes to mind.
Old 09-04-2010, 02:02 PM
djr76's Avatar
djr76 is on a distinguished road
I would make inserts and glue them in with loctite 638 retaining compound.
Old 09-06-2010, 01:08 AM
Cmailco's Avatar
Cmailco is on a distinguished road
Question
Virtually impossible to suggest something that approaches a "best practice" approach without knowing the volume needed.
More info please.
The Manufacturing Reliquary
http://cmailco.wordpress.com/
  #11   Ban this user!
Old 09-07-2010, 01:36 PM
Konstantin's Avatar
I have continued this here http://www.cnczone.com/forums/showthread.php?t=111580
Need A Quote- Aluminum tube m-134b Employment Opportunity 25 12-28-2009 09:01 AM
Best Way to Bend Aluminum Tube ??? twocik General Metal Working Machines 18 07-22-2009 01:39 PM
pressing aluminum into an aluminum tube Fishin_Rod Mechanical Calculations/Engineering Design 24 07-01-2009 12:23 AM
aluminum table tube dgalaxy DIY-CNC Router Table Machines 2 05-09-2005 07:23 AM
Where to find Aluminum Tube NeoMoses General Metalwork Discussion 3 01-22-2005 03:54 PM
