I've got to make a .25"(w)x7"(l)x1.5"(d) slot. I was considering roughing out the slot with a 1/4" twist drill at .26" spacing then finishing the slot with a long endmill. Is that a reasonable approach? Any reason just to slot with a extra long endmill instead? -Jim |
| Standard procedure for a slot like that with no particular finish considerations, within ±.010 is to simply slot with a 1/4" diameter 4 flute end mill (3 flute if non-ferrous) to the length-of-cut (5/8-3/4" down), then run the rest with a short length-of-cut end mill with 1.5-2" reach... the closer to 1.5" the better but you may have to go 2" to get an off-the-shelf grind. They're typically ground to ~.230" behind the flutes for whatever the length specification is. Follow the manufacturer's recommendations for axial depth of cut and inch/tooth.
__________________ The Manufacturing Reliquary http://cmailco.wordpress.com/ |
| Thanks Cmailco. Here is a jpg of the slot I'm trying to make. Are there any merits to doing a plunge rough with a twist drill and then cleanup with an endmill? It seems like that would greatly reduce the extremely light passes I'd have to make for the last 1" or so of the slot. -Jim |
Hate to answer with a question but I'm curious to know; is this a production run? How many do you need to make? What's the workpiece material? Thanks, Chuck
| It's a small production of 10 or less units and I'm doing it on my CNC'd X3 bench top mill. The material is 6061. The slot above is just part of the job, there is another 4 hours of machine time for each part. I'm trying to minimize time everywhere I can. -Jim |
#10
x2 , drilling is one of the fastest most efficient ways to remove material because the work is balanced torque along the spindle axis with almost no lateral loads on the machine...in other words the set up is the most rigid it can be permitting the highest removal rates ....and as you'll get say 100 sharpenings out of a drill its very inexpensive as well. |
#12
Lots of drill holes 15/64" or 7/32" to remove most of the material, then passes with a 6mm end/slot mill. A 3 flute one will run more smoothly (IMHO) Then some final passes climb milling to give the final width of 1/4" The reason for the 6mm and not 1/4" mill is so that it is always climb milling. Lots of flood coolant to keep the chips from being regurgitated. Make DOC about 3mm so as not to overload the cutter. With the flood coolant you can run 3000 rpm or so, if your spindle will go that fast. To identify the best feed rate examine the chips, and listen for smooth cutting. Solid carbide will work better, but it won't take kindly to overloading on intermittent cuts. Finishing pass with too much chip load will not give straight sides because the cutter will bend.
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. |
| How deep did you make your water tables? | microdot | Plasma, EDM and other similar machine Project Log | 7 | 01-02-2010 12:44 PM |
| milling deep thin slot | dlenardu | General Metalwork Discussion | 7 | 01-25-2009 08:23 PM |
| need to make a conical hole 2.4" deep | eyaliss | General Metalwork Discussion | 2 | 03-12-2008 04:20 PM |
| Coated Carbide 4Flute Endmill, 3Flute Slot Drill, or 2Flute Slot Drill? | weaston | General Metalwork Discussion | 7 | 04-11-2007 09:00 PM |
| anyone make their own t-slot linear bearings? | rkremser | 80/20, TSLOTS and other Aluminum Framing Systems | 7 | 06-09-2005 01:03 PM |
