Old 08-28-2010, 02:52 AM
Khalid's Avatar
Khalid is on a distinguished road
Grooving in Tubesheet Holes
We have large quantity of holes on Exchanger tubesheet... Recently i have converted the Radial drill into CNC and drilled the holes.. But how can we groove each hole?
You can see the drawing..I am using Visual Mill 6...
ID:	113566   Click image for larger version
Name:	combined tubesheetbaffles.jpg‎
http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
http://my-diysolarwind.blogspot.com/
Old 08-28-2010, 10:15 AM
Khalid, You might try this: www.cogsdill.com/products/recessing/
Dick Z
DZASTR
Old 08-28-2010, 11:31 AM
Khalid's Avatar
Hi Dick Z
Thanks for response.. I thought the tool should be like boring bar, with center entry into the hole..reach at specified depth then eccentric and make groove of specified depth...
We have grooving tools at our plant but we use them manually.. I just want to know how the CNC people doing with 1000 of holes grooving with CNC alone..
By the way interesting website..By the way, interesting website thanks for sharing
Old 08-28-2010, 04:01 PM
Khalid, You could use a tool similar to a woodruff key cutter, circular interpolate the grooves.
However, that will take more time. The Cogsdill tools can cut more than one groove at the same time.
As usual, what costs more, time or tooling?
Dick Z
add: The Cogsdill tools work fine with CNC, just a straight Z move down, slight dwell then retract. Been done many times on boiler tube plate and hydraulic valve bodies.
DZASTR
Old 08-28-2010, 11:42 PM
Khalid's Avatar
Thanks Dick Z... This help me a lot
Old 01-14-2012, 06:21 AM
Khalid's Avatar
Hi Dick,
How we can circular interpolate the groove? Any hints pls..
Old 01-14-2012, 09:31 AM
See post #4 above. Have your tool move into the hole (Z-axis down) on the hole center to the proper depth. Move the cutter in an arc till it reaches diameter you want, interpolate a complete circle. Bring the cutter back to center and retract or move to another depth and cut another groove.
Be sure to always move back to center befor moving in Z-axis.
Dick Z
DZASTR
Old 01-15-2012, 12:54 AM
Khalid's Avatar
Thank You Dick Z..
I will try
Need Help!- INTERNAL GROOVING BILLYD General Metalwork Discussion 3 05-20-2009 06:43 PM
Need Help!- Grooving HELP! modeltruckshop@ General Metal Working Machines 4 04-22-2009 08:49 PM
od/face grooving bala955 Surfcam 1 01-30-2009 09:50 AM
Face grooving penjas14 General Metalwork Discussion 1 12-05-2008 11:05 AM
What is the G code for Grooving? Not G75? cjchands Mach Software (ArtSoft software) 7 04-22-2007 05:07 PM
