Old 08-27-2010, 06:00 PM
PoiToi is on a distinguished road
How to join carbide to withstand high temps?
Hi all, I have a somewhat strange question. I have to opportunity to use a bunch of scrap carbide to make a sculpture. I know I can join carbide to carbide with brazing, but the brazing won't hold up in high temperatures(think propane flame).
Does anyone know an easy way to join 2 pieces of carbide that's relatively heat-proof??
Thanks in advance.
Old 08-27-2010, 10:28 PM
Eurisko is on a distinguished road
Not sure exactly what you have in mind... how about 3000 degree castable refractory cement?
Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers
Old 08-28-2010, 12:38 AM
looked into it and it sounds promising, will it bond to carbide??
Old 08-28-2010, 04:02 PM
I can't say - because I've never tried. My only experience with refractory cement was in building an electric kiln for metalcasting. Used it to join lightweight firebrick for the kiln base and lid. The brick is incredibly light and porous, and bonds well to the cement.
There are different curing techniques, depending on the type of refractory cement you're using.
Will your sculpture be subjected to high temps after it is completed? Can you give more details?
Old 08-28-2010, 04:41 PM
sld4121 is on a distinguished road
Silver braze will hold up to oxy-acetylene, unless the parts are so small that you wil be heating parts that are allready joined. In which case, the silver solder will flow again.
spindle temps? xaruum Taig Mills & Lathes 26 07-25-2010 09:22 PM
Withstand the Test of Time with Simplicity® Technology Pacific Bearing Product Announcements & Manufacturer News 1 03-10-2009 10:05 AM
High Quality Carbide Burrs rjsupply General Metalwork Discussion 0 03-27-2008 12:28 PM
SX3 Spindle/Head temps extrapilot Syil Products 3 11-11-2007 12:32 AM
Painting hardwood sign to withstand direct sunlight/wx spoiledbrat WoodWorking 3 07-09-2007 11:05 AM
