Old 08-11-2010, 09:08 AM
Uncle Snake is on a distinguished road
Inconel 718 cutting parameters??
It looks like I've got a bunch of this stuff to mill, what have you had success with?? I'll be using mostly Ticn coated Helical brand end mills and various branded carbide drills and thread mills. The machine is a Milltronics VM24, cat 40. Thanks in advance.
Old 08-11-2010, 05:40 PM
03clipse is on a distinguished road
I have done alot of it on a lathe but not much on mill. The closest I have on a mill was alloy 75 the best thing I found to use was surfcam trumill i can run at tail pucker speed and feeds. I would recomend a MA ford 7 flute end mill the part number for the .500" i use is 18050012B look it up and see what you think
Old 12-30-2010, 01:55 PM
jamesu229 is on a distinguished road
Try 250 ipm
We just tested our endmill grind on inconel 718 at 960sfm and 250 ipm. here is a link to our video on youtube.
YouTube - High speed machining 718 Inconel
cutting inconel 718 stsrvanvliet General Metalwork Discussion 12 03-18-2009 09:08 PM
Need Help!- cutting parameters for natural peek fsa General Material Machining Solutions 0 07-04-2008 11:30 AM
cutting inconel dry stsrvanvliet General Metalwork Discussion 3 11-14-2006 07:01 PM
cutting parameters captahab CNC Wire Foam Cutter Machines 0 01-15-2006 10:11 PM
cutting inconel teilhardo Composites, Exotic Metals etc 3 03-19-2004 05:02 PM
