Old 08-06-2010, 11:35 AM
Clyde Altemus is on a distinguished road
#4 JIC Cutter
Where can one buy #4 JIC form cutter?
Old 08-06-2010, 10:24 PM
Is this a porting tool for hydraulic fittings? Need more clues.
Dick Z
DZASTR
Old 08-07-2010, 09:22 AM
Yes, it is a porting tool. #4 JIC
Old 08-08-2010, 11:03 AM
Try www.hpwetmore.com
Dick Z
DZASTR
Old 08-09-2010, 07:50 AM
DICKZ<
Thank you for your help.
Clyde Altemus
Problem- T SLOT MILLING CUTTER PACKAGE 5 (ON WALTER CNC CUTTER GRINDER) dharschman Toolgrinding & Toolgrinding Machines 3 09-13-2010 12:25 PM
CNC Laser cutter versus CNC Plasma cutter? squale Laser Engraving & Cutting Machines 10 04-26-2009 04:59 PM
Tool & Cutter Grinder and Wire Cutter Plans newport CNC Wire Foam Cutter Machines 1 04-17-2009 04:15 PM
Cutter comp on an id hole< cutter diam.?? PaintItBlue Haas Mills 5 05-05-2008 06:30 PM
How do I use a dove tool cutter & slot cutter bobby1 BobCad-Cam 2 04-15-2008 08:06 PM
