I need to put some 3/16" dia. holes in some 1/8" x 1 1/4" stainless steel (304) flatstock. The holes need to be at a 63 deg. angle from the drilling axis (27 deg. off of the horizontal table surface of the drilling equipment). I don't have a milling machine and want to know if I can do this with a drill press if I'm carefull about feeding the bit and clamping the work. If this is feasible with a drill press what style of end mill should I use? It seems to me that a ball end mill won't try to grab the work the way a square end mill might and won't skid the way a drill bit would. I need to make a total of 18 holes. This is part of a stair railing system for an outside deck. Thanks for any suggestions. Chris |
| I do think it can be done. But with a high speed steel cobolt cutter and a tool change.. Mill the flat for drilling.. Sounds kinda teedious though. How many holes do you have to drill? Try a TTC E20-501-155 at 11.52 Each from https://www.travers.com/index.asp That should do the trick for a high angle. Post some pictures when you get the chance. |
| OCNC - I think this could be done - obviously a mill would be better for rigidity, but - The problem you will likely have is that the tool is going to grab on both entry and exit - you know this obviously. A carbide tool is likely going to shatter on a drill press unless it is a hefty drill press with a stout spindle. Using cobalt tools sounds reasonable as they seem to be more forgiving to abuse, and a ball end mill is worth a shot. Watch your speeds and keep the tool and material cool somehow - stainless can work harden like a Swedish secretary. The other thing you could do to help is use a spot drill - a drill with almost no flutes - and use a piece of wood as a drill guide. The bad thing is that spotting drills are typically only two flutes, but maybe you can improvise somehow using some sort of guide. ...just some thoughts - likely not all that helpful. Sorry. Scott
__________________ Consistency is a good thing....unless you're consistently an idiot. |
I've got 18 holes to drill. I hadn't thought about making this a two step operation but it makes sense in lieu of using a drill press instead of a miller. What do you think about using a carbide burr with an end cut to mill the flat? It seems like it would be less likely to grab. Chris |
| A Carbide Burr would be safer if you do not have the rigidity of a mill, but I suspect that you will destroy quite a few in the process. The key is a very sharp cutter and keeping the cutter cool and free of chips to avoid work hardening. Are you going to build some sort of work holding jig/clamping jig for this? |
| How long is the piece of stock? Have you checked the runout on your drill press...I suspect that you'll wobble through a hole or two if you're lucky. I suspect the holes are for some sort of spindle? I think your best bet is to drill an undersized hole perpendicular to the surface.....then you could use a reamer, burr, or stone with the drill press or a surface mounted jig to angle the holes. |
Chris |
| How to cut holes in Autocad | Sanghera | SheetCam | 5 | 05-28-2005 12:32 PM |
| head stock and tail stock chucks | mocnc | DIY-CNC Router Table Machines | 3 | 10-19-2004 09:16 PM |
| Finding metric stock | Konstantin | General Metalwork Discussion | 3 | 09-12-2004 11:28 AM |
| Drill holes for flat cap screw | starCNC | General Metal Working Machines | 7 | 09-09-2004 09:47 AM |
| Need help with T-Slots - Boring holes | samualt | DIY-CNC Router Table Machines | 14 | 04-10-2004 10:39 PM |
