Old 07-22-2010, 07:47 PM
dingo0722 is on a distinguished road
single pass on 304SS 5/16 thick
I am profile cutting a small part with an outside profile of about 6 inches. The material is 304SS. I have all the drilling and chamfering of the part down but am struggling with cutting the part out of the stock. Currently I am drilling all the features into the stock plate. Then I secure the part each piece prior to cutting out with screws through the drilled holes into a board below. I am profile cutting the part out using 1/4" HSS 2 flute running at 1300 RPM and a feed of 1.25ipm with 4 passes. I am getting tooling failure after cutting out 6 pieces. The stock material hold 11 pieces. I am entering each part off the stock material and side cutting the whole time. I was thinking of going with a roughing endmill to pick up the pace, do a single pass cut and hoping to get the tool to last longer. Is this possible? any help and thoughts would be much appreciated
-Dan
Old 07-22-2010, 08:22 PM
metalworkz's Avatar
metalworkz is on a distinguished road
Hi Dan,
Do you think the material is work hardening?
Regards,
Wes
Old 07-22-2010, 08:50 PM
I have run into that. I have found that running a carbide endmill I could never get the speed and feed correct which caused the part to work harden and destroy the tool.
with the HSS, the tool will cut for a while then rapidly fail. I suspect this is a speed/feed issue that I just haven't been able to figure out.
Old 07-22-2010, 09:22 PM
xclr82xtc is on a distinguished road
make several passes, and chnage the code so that every few passes it changes the z to use a lil different spot on the tool
Old 07-22-2010, 09:25 PM
I changed the code so the tool starts off the part in stead of plunging on the part. This made a big difference but still getting premature tool failure(premature as far as I am concerned)
Old 07-23-2010, 02:44 PM
Shane123's Avatar
Shane123 is on a distinguished road
use a niagra fine tooth roughing endmill, leave about .01 on your xy surfaces, then come around and clean that with your carbide. the cheaper fine tooth roughers have larger teeth than the niagra, hence why i suggest using niagra brand if possible. if you have clearance, use a 1" or 3/4" diameter rougher, seems to last longer. 99% of our work is stainless, and i finally got the purchasing staff to order 303 whenever possible to save on tooling. 304 is soooo inconsistent on plate. use a 4 flute finisher if possible, keep your chip load down.
Old 07-23-2010, 02:47 PM
Shane123's Avatar
if you do go with the niagra, speed of around 750 for either of the 2 recommended diameter cutters. feed of 5 - 6 ipm, your tool will let you know what it likes.
Old 07-23-2010, 04:58 PM
jamesu229 is on a distinguished road
Check out how we run 17-4 stainless. these cutters should do well slotting in 304 also
YouTube- HIGH SPEED MACHINING(REALLY HIGH!!!)
Old 07-23-2010, 06:22 PM
djr76's Avatar
djr76 is on a distinguished road
what this guy said,
1 pass for rough, 1 pass for finish and flood the crap out of it to cool and flush chips. Id go with a .500 rougher since you will be able to run it faster than a .75 - 1.00 diameter endmill and finish it with a .250 carbide.
Old 07-23-2010, 07:33 PM
Shane123's Avatar
Originally Posted by djr76 View Post
what this guy said,
havent had the best luck with .5 diameter, what speed/feed you running? i know the .75 and 1.0 will do full radius cuts fairly easily, but the .5 seems to wear itself out on me. i must be running it too hard or not hard enough.
  #11   Ban this user!
Old 07-25-2010, 07:40 AM
djr76's Avatar
I run 304 on the slower side. For hss fine tooth roughers, 30-50 sfm .001-.002 ipt. with flood coolant. So for .500 diameter hss rougher, 350 rpm is a good starting point.
  #12   Ban this user!
Old 07-25-2010, 01:58 PM
350 RPM. I am way above that and that could be my problem. I am running around 1200 at 2.5IPM. I have some 3/8 Colbalt roughing endmills on order I will give them a shot at a lower RPM and same feed which will be with in your 0.001 to 0.002 parameters for a 4 flute
Single Pass Letters... wmgeorge WoodWorking 2 11-18-2008 11:44 AM
Four Carriages on Two 15mm Rails or a Single Carriage on a Single 45mm Rail ??? joprinz Linear and Rotary Motion 12 10-07-2008 06:08 AM
Drilling 304SS TT350 General Metalwork Discussion 6 11-27-2007 07:41 AM
Single Pass Fonts bill south Engraving Machines 9 06-02-2007 07:49 PM
:RFQ: 2 304SS Flanges CarTunr22 Employment Opportunity 2 03-05-2007 09:48 PM
