Old 07-19-2010, 03:33 PM
eliot15 is on a distinguished road
Chamfer calculation
I'm trying to figure out how to calculate the 'Z-depth' value on say a G73 canned cycle for a .75" bolt hole. Lets use a chamfer diameter of 1.5".
If I were doing a 90 degree chamfer, I'd just bring my counter sink down till it touches in my bolt hole, take that depth (say -.123) and add it to (1.5 - .75) /2. So we get .375 + .123 = .498. So my G73 Z address value would be Z-.498, plus a little tolerance.
How do I do the same sort of calculation with an 82.5 degree counter sink?
Any help much appreciated.
e
Old 07-19-2010, 04:59 PM
Eurisko is on a distinguished road
That requires a little trigonometry.
First, divide 82.5 by 2, then find the tangent of that angle:
82.5 / 2 = 41.25
tan(41.25) = .8770 ( to 4 decimal places )
Take the diameter of the required chamfer, subtract the hole size, divide by 2, then divide by .8770
for example, your 1.500 chamfer would be :
(1.500-.750) / 2 / .8770 = .4276 ( to 4 decimal places)
This is the amount you would feed in Z with the chamfer tool just touching the hole.
Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers
Old 07-19-2010, 07:03 PM
Thanks a million!
Just to be sure I undestand, I'm using an indexable countersink. I'm assuming I would have to bring the tool down to part zero, then drop the countersink into the hole until the inserts touch the sides of the hole, then add that distance to .4276 in the eample above.
Here are the numbers I actually worked with today:
My countersink inserts touched at Z-.168.
Chamfer (1.38) - Hole (.755) / 2 = .3125.
.168 + .3125 = .488.
So I initially set my Z-depth to Z-.488. That gave me a chamfer diameter of about 1.32. I finally got the chamfer diameter I wanted by increasing my Z-depth to about .538.
So, using trig:
(1.38-.755) / 2 / .8770 = 0.3563( to 4 decimal places)
Adding .168 to 0.3563 = 0.5243, which gets me just about to .538.
I wasn't sure if your remark:
was assuming that .168 was added in or not. Just wanted to be clear. I need a Z depth of about -.540 to get the 1.38 chamfer.
Is that all correct??
Thanks for your time.
e
Old 07-19-2010, 08:13 PM
I think you've got it. Yes, you would have to add the .168 (Z position with chamfer touching hole) to the trig calculation to get the final Z value.
It could be that the chamfer angle isn't exactly 82.5 degrees, that would explain why a little more depth was needed. Also, a chamfer diameter is tough to measure exactly. That throws another variable into the mix. Add tool pressure & flexing, and the numbers make sense.
Old 07-19-2010, 08:55 PM
Great. Thanks again for that. I'll be using it constantly.
Also, .168 + .3125 doesn't = .488. My bad. It equals 0.4805. I threw in about .008 to shoot for the middle of tolerance.
2D chamfer jcnewbie Mastercam 5 10-18-2009 11:06 PM
Grinding a chamfer? pp-TG General Metalwork Discussion 5 02-28-2008 05:33 PM
Chamfer CharlesM479 Solidworks 3 04-11-2007 11:13 PM
Trying to chamfer some letters justCNCit Rhino 3D 29 02-08-2007 02:41 AM
Chamfer on surface Beaker Mastercam 5 11-15-2006 04:32 AM
