Old 07-17-2010, 10:02 PM
cnczoner is on a distinguished road
How do I coat steel to rust-proof it?
My first steel part -- it's a spindle wrench. And it works beautifully! Now how do I coat it to protect it? I expect paint will come off where it meets the spindle. Plasti-Dip? What else that I can do myself without taking it to some chrome plating company, etc? Appearance not important.
Thanks,
-Neil.
Old 07-18-2010, 12:18 AM
Dorsal is on a distinguished road
You might want to go to a local gunsmiths or hunting supply store and buy a gun bluing kit.
Old 07-18-2010, 12:23 PM
Hmmm... heard that term before, but not familiar with the process, so I'm looking it up. Wikipedia's first sentence on bluing says "Bluing is a passivation process in which steel is partially protected against rust". Partially? They go on to say things like "...this finish is also the least effective at providing rust resistance", and "All blued parts still need to be properly oiled to prevent rust".
Now I know wikipedia has been wrong before, but these statements are a bit concerning. Or are you referring to some other or variation of this process?
Old 07-18-2010, 01:29 PM
bwprice100's Avatar
bwprice100 is on a distinguished road
Hi Neil
Some information on the environment you plan to sue the wrench would help in giving advice.
Brian
www.eBolt.co.uk
http://stores.ebay.co.uk/ToolsAndBolts
Old 07-18-2010, 02:37 PM
Sitting next to the mill. Since I started using kool-mist (rather than WD40), I've noticed that a lot of parts started developing rust (collets, mill table, etc), so I've started wiping down some of these parts with WD40 when I'm done milling. However, I don't quite like the idea of wiping down a hand-tool with anything slippery.
Old 07-18-2010, 03:02 PM
OHLEMANNR is on a distinguished road
Gibbs
http://www.roadsters.com/gibbs/
Bob
Old 07-18-2010, 03:21 PM
bwprice100's Avatar
I would degrease it and then spray paint with a zinc rich paint.
Brian
www.eBolt.co.uk
Old 07-18-2010, 04:06 PM
Originally Posted by OHLEMANNR View Post
Gibbs
Bob
That seems to be a penetrant/lubricant, and that web link says "Gibbs Brand leaves metal slippery", which is generally not a good idea for a hand tool. Did you perhaps link to the wrong page?
Old 07-18-2010, 04:51 PM
Eurisko is on a distinguished road
This link describes galvanizing steel by immersion in molten zinc:
http://corrosion-doctors.org/Definit...alvanizing.htm
Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers
Old 07-21-2010, 04:36 AM
Tempus Fugit is on a distinguished road
do you have stuff called Hammerite 'Kurust' ?
it's a thin milky-white liquid in a small white plastic pot you apply by brush, which I have used on various tools (and other rusty stuff), ends up turning the surface black, ready for painting or not. Some sort of chemical action rather than just a paint.
Probably available from car accessory shops
  #11   Ban this user!
Old 07-21-2010, 07:25 AM
Never heard of Kurust, but I will investigate. Still also have to investigate the zinc-rich paints and galvanizing.
I was thinking that a few coats of engine enamel paint may hold up, but also thinking of powdercoating (using HF's $100 kit). I know the latter is relatively thick, but it should be relatively simple to run an experiment to determine the thickness and grind off the correct amount from the inside of the tool's "teeth" using a dremel.
Cheers,
-Neil.
  #12   Ban this user!
Old 07-21-2010, 07:27 AM
mrcodewiz is on a distinguished road
What part of the country are you in? I mix it about double what they suggest and I never have an issue with rust.
Hard Coat Applicator for EPS TomHay Product Announcements & Manufacturer News 7 10-28-2011 07:12 AM
Newbie- Coat metal plates with logo/info tag nearbeer Moldmaking 0 03-18-2010 07:30 PM
Where to buy powder coat? Sporqster Mechanical Calculations/Engineering Design 12 10-25-2006 12:24 PM
I'm looking for someone to cut and coat custom foam parts decor designer Machinist Feedback 4 08-21-2006 05:44 PM
wet proof mdf dertsap DIY-CNC Router Table Machines 24 12-19-2005 12:13 PM
