Old 07-17-2010, 05:50 AM
electric2u is on a distinguished road
aluminum verise steel tubing
question maybe wroung place,
Steel tubing verise aluminum on building a cnc. the spectes i see say the steel wall can very .020 or so. the bigges problem is i have a welder, but nothing to weld aluminum with. what are you thoughs on staightness on this.
thank you, kevin
Old 07-17-2010, 06:08 AM
kevin swan is on a distinguished road
Howdy Neighbour
What type of tube? square will very. round will be quite uniform. pipe will be all over the place in size and not very round
Old 07-17-2010, 06:42 AM
i was looking a 1x3 steel tubing. i just what it to be stright
Old 07-17-2010, 08:07 AM
nofx is on a distinguished road
Use a linear rail system attached to the square tubing and that will be square.
Bending square tubing steel MBG Bending, Forging,Extrusion... 4 08-02-2009 11:40 AM
Pricing for steel tubing mdierolf General Material Machining Solutions 7 06-17-2009 12:34 AM
Steel Tubing CNC Router thegimpster DIY-CNC Router Table Machines 70 05-03-2008 06:41 AM
Bending stainless steel tubing eljainc Bending, Forging,Extrusion... 5 12-27-2007 01:08 AM
diy vmc from rectangular steel tubing ? andy55 Vertical Mill, Lathe Project Log 7 01-02-2006 03:59 PM
