Old 06-20-2010, 09:02 PM
edge540's Avatar
edge540 is on a distinguished road
Feeds/speeds, etc for 304ss
I need to machine some 304ss plate with a 3/8 end mill on my Haas VF-2 with fairly tight tolerances like .001 flateness and parallell on .15" thk 3x3 squares. Pocketing and profiling (no plunging). I have been machining 4130 and mild steel w/ coated end mills with good success. Is the stainless going to be alot more difficult to machine than the steels. Any advice or tips would be a big help. Rather not trash a 100 dollar tool by doing something wrong.
myspace.com/1metalmorphose
Old 07-29-2010, 08:31 PM
laka is on a distinguished road
200 SFM and 0.001" per flute should be pretty safe if you're using a coated tool. Use plenty of coolant.
Old 07-29-2010, 09:07 PM
Shane123's Avatar
Shane123 is on a distinguished road
stainless doesnt like to spread the heat, so go hard on feed and not soo much on speed, keep the heat in the chip. i hate 304 plate with a passion, as i find sooo many inconsistencies in it as i machine. i usually try to use insertable or actual roughing endmills to do any roughing and then just simple side profiling of .01 cleanup with finish tooling. oh yeah, i hate 304 plate
Old 07-29-2010, 11:01 PM
edge540's Avatar
thanks guys. I didnt get the job which im sure is for the best because I had this feeling the things would potato chip on me. I have done plenty of fabrication w/ 304 and it doesnt like to have anything done to it so i feel your hate. will store your info away none the less for future reference
Feeds and Speeds tac8357 Mentors & Apprentice Locator 1 06-26-2008 09:50 AM
Speeds n Feeds jessbussert WoodWorking 12 06-12-2008 11:09 AM
Need some help with speeds & feeds ldkell_2000 General Metalwork Discussion 6 03-01-2008 10:35 AM
feeds and speeds porkchop21 Bridgeport and Hardinge Mills 2 08-30-2007 07:52 PM
feeds and speeds rchprks General Metalwork Discussion 2 07-17-2006 06:48 PM
