Results 1 to 4 of 4
Thread: how hard is 7075
    Mar 2010
    how hard is 7075
    How hard is aluminum 7075 to lathe? Its the hardest but it is still Easy and easy on the tools?
    Feb 2008
    Smile
    Your question is not complete, 7075 comes in a number of tempers F, O, H, W and T. There are 3 subdivisons H1 H2 H3. The degree of Strain hardened are next and follow the second digit following one of the two above, 2 = 1/4 hard, 4 = 1/2 hard 6 =3/4 hard, 8 = full hard. and lastly 9 = extra hard.
    Anyway the most common 7075-T6 or T651. It is very nice to machine and has a tensile strenght of 83,000 psi and yield of 73,000 psi. So to kind of answer your question... if I look up 83 ksi that = 170 Brinell hardness. However most references list it at only 150 Brinell and I'm not sure why.
    Steve
    Mar 2009
    7075 Al is a blessing to machine. It's hardness makes it machine in a "crisp" manner, low galling on tools. Any AL specific tooling (sharp) is a good start for lathe and mill. Just beware that if you remove a lot of material from for example one side of a plate, it will warp(banana) when the stress is relieved from the one side. In other words doing a rough cut on both sides of part before machining final surfaces might be in order.
    Drill 1/4"-3/8" hole in drill press first into 6061 and then 7075, you will understand what crisp means...
    Mar 2010
    its for T651. Thanks
  1. Specs For 5 and 6mm pressfit in 7075
    By DATTAMAN in forum General Metalwork Discussion
    Last Post: 12-01-2009, 12:18 AM
  2. WTB - 7050 / 7075 Al strip 1/4 in x 3 in
    By harryn in forum Want To Buy...Need help!
    Last Post: 03-15-2008, 12:56 PM
  3. Perfrormance in 7075 T-6 aluminum
    By DragnsBane in forum Tormach Personal CNC Mill
    Last Post: 02-22-2008, 03:59 AM
  4. Milling 7075
    By warpedmephisto in forum General Metalwork Discussion
    Last Post: 03-29-2006, 08:23 AM
  5. 7075 Aluminum
    By mtechserv in forum Moldmaking
    Last Post: 03-27-2005, 11:27 PM
