could i hear some general percentages of cutter dia. that one would use to step over when milling, along with the depth of cut. it seems to me that a larger step over with less depth would be better because the chip would then be the correct thickness? when doing a full dia cut is it common to drop the feed rate to 1/3? thanks |
| Actually step-over has more to do with how flat do you want a surface to be. Based on my limited experience....it seems that most milling bits have some radius..so rather then creating a true flat cut you end up with a cut that is cupped. So, step-over reduces the height of the ridges of the cupped cut. Paul |
| If the step-over leaves "cupped" or "notched" surfaces, the machine's geometry is messed up. If this happens, tram the machine and correct the geometry. If that doesn't work, I'd use a fly cutter to put on the final finish cut. But then I'm picky. Dick Z
__________________ DZASTR |
| so really you would want to take a 100% step over and shallower cut depth for roughing and finish with a larger depth of cut and small steps? And again, will the stepover amount of 20% vs 50% change chip thickness? when a manufacturer says that the tool should be set up for .002 chip load and you run your forumlas is the formula feed assuming that you are doing 50% dia step over? |
| minimum amount of material in vise | charlie_luna | Work Fixtures and Hold-Down Solutions | 6 | 02-01-2010 11:07 AM |
| Need Help!- Controlling the amount of tool overshoot in parting off/grooving?? | Captdave | Mazak, Mitsubishi, Mazatrol | 4 | 12-22-2008 06:11 PM |
| Need Help!- G53-Z SHIFT AMOUNT NEGATIVE | coondog | Daewoo/Doosan | 3 | 05-16-2008 10:21 PM |
| amount of bend in metal | myinisjap | Mechanical Calculations/Engineering Design | 3 | 02-18-2007 08:52 AM |
| ball screw lead amount | replicapro | General Metal Working Machines | 17 | 07-03-2004 07:59 AM |
