Old 06-10-2010, 02:03 PM
dsyrotiuk is on a distinguished road
8620 cold rolled bar
In the past year our tool life went from 160 pc's down to 40 pc's on the roughing insert turning 8620. We are having trouble breaking the chip and part incosistancies. I have checked the heat and found that the sulfer content was around .01-.013 (range is .04 max) Has anybody been having this problem.
All metal Z-axis design useing skate bearings and cold rolled steel FandZ DIY-CNC Router Table Machines 25 07-24-2009 08:24 PM
cutting oil for 1/4" cold rolled steel? groomden DIY-CNC Router Table Machines 13 03-18-2009 11:50 PM
Cold Rolled Steel Accuracy Zach_G Mechanical Calculations/Engineering Design 13 11-25-2008 08:59 PM
Cold rolled steel, flats or square for use as rails. Apples Linear and Rotary Motion 10 08-09-2008 12:22 AM
Need to cut 1 x 4 cold rolled steel - Product Review jderou General Metal Working Machines 17 07-06-2005 11:24 AM
