Our design dept is getting 'creative' again, and has asked me if it's possible to machine a thread. The catch is, the thread is a taper thread which then runs smoothly into a parallel thread. In other words, we have a bar with a taper at the end. Then we want to put a thread on all of it, smoothly running up the taper and along the bar, all at the same pitch, same form, etc. No, I don't really know why they want to do that. Now of course there are lots of ways to do it, but none of them are particularly easy.... Any thoughts? At my disposal I've lots of 4 axis mills, a 5 axis integrex mill-turn and a few two-axis lathes. |
| kiwi - that's the method I've in mind, running a single point form tool around the part on a milling machine. I've no problem with making the part, or programming the machine, I'm really just looking for ideas for methods or techniques to do it as easily as possible. |
| This is being done on an EMC2 control but I have to think Fanuc or Mit could do the same. They are using a bunch of macro stuff but in the end it is just a bunch of G33 commands. http://jmkasunich.com/cgi-bin/blosxo...k/fusee-1.html |
Wow, that's some impressive stuff on there. |
Provided your machine can use G32 it is not particularly difficult. You simply have to code a few more lines because G32 requires you to program all the moves including the return.
| weird "taper" problem | Teyber12 | Benchtop Machines | 9 | 04-07-2010 09:01 PM |
| Need Help!- NPT Taper-to-Straight-to-NPT-Taper Thread | bdyenter | General Metalwork Discussion | 2 | 09-16-2009 08:10 AM |
| Need Help!- Thread Milling a Taper | automizer | G-Code Programing | 19 | 06-12-2008 10:23 PM |
| Newbie- taper thread cutting | cncmc | Mazak, Mitsubishi, Mazatrol | 4 | 05-05-2008 04:59 AM |
| taper thread | gcrandall | Mazak, Mitsubishi, Mazatrol | 4 | 05-17-2006 10:13 AM |
