Results 1 to 1 of 1
Thread: TM20V for tube mitering
    Jun 2010
    Hi there, first time poster so dont even know if this will work BUT...
    I am considering purchasing a Titan TM20V mill/drill for the purposes of mitering thin wall CroMo tubing (wall thicknesses between 0.7 and 1.0mm) using high quality hole saws. The miters will be at a range of angles between 90 degrees and perhaps 60 degrees or less. The tube diameter could be as small as 12mm up to about 32mm.
    Anyone out there have an expert opinion about wether or not a unit like this would be up to the task in terms of being able to provide reliable, accurate results. The miters need to be very accurate in terms of shape, angle and lateral position on the tube.
    Thanks in advance.
    P.S. here is a link to the mill machine in question: http://www.machines4u.com.au/view/ad...advert_id=9728
    Last edited by Steelturn; 06-07-2010 at 10:00 PM. Reason: Adding link for item in question
  1. You Tube
    By M250cnc in forum Test Forum
    Last Post: 04-07-2010, 11:20 AM
  2. Newbie- Tube cutting; tin slots and tube ends
    By marineboy in forum General Waterjet
    Last Post: 10-13-2009, 05:03 PM
  3. Tube Reaming
    By ALLtra Mach in forum General Metalwork Discussion
    Last Post: 10-26-2008, 01:44 PM
  4. Is this a bad tube?
    By FlyGuy007 in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 06-13-2007, 06:44 AM
  5. Tube through a Plate
    By CharlesM479 in forum Solidworks
    Last Post: 04-14-2007, 02:33 AM
