Old 06-07-2010, 02:18 PM
kendo is on a distinguished road
mill a V-channel in 304 sst
I need to mill a V-channel in a piece of 304 Stainless, its .060" deep, 90 degrees.
I was gonna throw a drill-mill at it, but the customer wants no flat in the bottom
Y'all think a full-point engraving bit would hold up allright?
Maybe if I rough it with the drill mill 1st?
How hard would ya feed the engraver with that fine point through this tough stuff?
thanks for any advice you may have
-Kenny
Old 06-09-2010, 07:08 PM
rbcmetalwork is on a distinguished road
Perhaps a double angle milling cutter.
I've used the 60-degree engraving tools on 303 stainless steel. The sharp tip didn't hold up well. This was only cutting .015" deep.
Randy
SV-2412, 0i Mate-MB
Old 06-09-2010, 08:15 PM
Thanks, but I dont see how that would work in my application...
The channel is actually a rectangular "race track" 4 x 2", with 1/2" radius in the corners
Old 06-12-2010, 10:55 AM
Delw is on a distinguished road
Thats going to be a tough one on tools.
Grinding would be best. A engraving tool would work buts going to be slow
another option I have used is a carbide slittling saw and have it ground, and mount the work pcs in a 4th axis or up against a angle plate. the picture posted above would work if you have clearance. the more teeth the better in 304 ss.
with out knowig what type of mill its going to be cut on, how deep and wide the groove is and along with your capibilities its going t be hard to tell you how to do it.
Old 06-12-2010, 11:11 AM
neilw20's Avatar
neilw20 is on a distinguished road
A sliting saw won't work.
Delwa !!!
After the slitting saw goes around the 1/2" radius corners it won't be too healthy.
Kendo.
Might be easier to make a copper positive and spark erode it.
Good tool life, but not too easy on a standard mill.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 06-12-2010, 12:34 PM
Kenny, I do not know what your machine looks like or spindle rpm capability. Back in my ancient history we milled such slots with single lip carbide end mills using air blast for coolant and chip removal. This was cutting D-2 at 58-62 Rc.
CAUTION Nasty sharp little chips !!!!! Eye protection mandatory !!!!!! Sharp little buggers stick in your fingers too. LOL
Dick Z
DZASTR
I/O Channel Parameters Probe Guy Fanuc 4 11-06-2008 01:33 AM
Cutting in channel WEDM Laser Engraving & Cutting Machines 1 07-18-2008 11:17 AM
80/20 versus u-channel SteveT44 DIY-CNC Router Table Machines 4 11-19-2005 04:39 PM
IRC channel for EMC Dan Falck LinuxCNC (formerly EMC2) 0 12-18-2004 11:03 AM
Two steppers from one channel? m1911bldr General Electronics Discussion 1 03-29-2004 08:30 PM
